Here come the mi 10 ultra and k30 ultra!
Nakedtoes
Best is get phone with OIS also cause most EIS also use the cropping method to compensate for yr shaking while taking photo.
Tsoukalos
what's the max optical zoom with OIS for hp in market now or just released? oh & also do those mobile lens attachment to increase optical zoom really work? how many x is best? i see online got up to 50 x that look like machiam sniper scope sia w tripod stand. most like 10 to 12x?
NightRaven49
photo doesnt use eis, relies on ois for stabilisation. eis is more for video which is continuous capture.
Nakedtoes
Photo have lar.. U go find one that have and take pic with and without.. See the edges it capture.
Nakedtoes
Most in the market is 5 x optical only.. The higher u go the longer the lenses group.
benqdell
Hopefully this chip will make it and mediatek will continue to challenge Qualcomm. Qualcomm is just overcharging with the 865
Dont think qualcomm is the one overcharging if oneplus or other manufacturers can use the same chip and sell their phones at a lower price compared to others.
Nakedtoes
Don't think photo have eis.
I'm quite anal about ois.
Have leh.. The camera app can on or off image stabilizer.. I tried last time with I think is k20 pro. Took 2 photos.. The one with eis on the sides are crop away.
Nakedtoes
U sure? U tell us which sd865 phones is cheaper then xiaomi.. Pls.. Lol
Nakedtoes
i see... any advise for the mobile lens then?
Toking abt optical quality.. Ask yr self do u use zoom often.. Usually I would said a wide lenses more important. And best is those with OIS instead of EIS. If u want the best the vivo x50 pro with gimbal quality of ois is superb.
NightRaven49
The eis feature or how it works is same as taking video. If not how come the photo look slightly zoom in?
https://en.wikipedia.org/wiki/Image_stabilization#Digital_image_stabilization
This technique shifts the electronic image from frame to frame of video, enough to counteract the motion.
eis compensates from frame to frame of the video to be stabilised. this miui cam feature just uses the gyroscope to measure the angle of the phone, completely different method. of course its zoomed in cos have to rotate the photo mah, not like u can capture outside of the sensor.
cosycatus
No 3.5mm headphone jack.
I check official website.
Ok. Move on with my life
Next phone.
effendy.lesmana
I was thinking to buy this Mi10 Ultra, in shopee got store sell this already.. but since its a china version what is the pros and cons about it? can we use in singapore? compatible with SG apps like banking? singtel? or gov apps?
I never tried china version before..
