Best is get phone with OIS also cause most EIS also use the cropping method to compensate for yr shaking while taking photo.
photo doesnt use eis, relies on ois for stabilisation. eis is more for video which is continuous capture.
Selfie camera is hidden, will popup when activated.I saw it says
What's a pop up full screen?
what's the max optical zoom with OIS for hp in market now or just released? oh & also do those mobile lens attachment to increase optical zoom really work? how many x is best? i see online got up to 50 x that look like machiam sniper scope sia w tripod stand. most like 10 to 12x?
Most in the market is 5 x optical only.. The higher u go the longer the lenses group.
Photo have lar.. U go find one that have and take pic with and without.. See the edges it capture.
Hopefully this chip will make it and mediatek will continue to challenge Qualcomm. Qualcomm is just overcharging with the 865
Don't think photo have eis.
I'm quite anal about ois.
Dont think qualcomm is the one overcharging if oneplus or other manufacturers can use the same chip and sell their phones at a lower price compared to others.
so it's optical zoom 5 x but is equal to optical 10x cause come w periscope lens? sorry noob
i see... any advise for the mobile lens then?
Have leh.. The camera app can on or off image stabilizer.. I tried last time with I think is k20 pro. Took 2 photos.. The one with eis on the sides are crop away.
thats a miui cam feature, its not eis.
The eis feature or how it works is same as taking video. If not how come the photo look slightly zoom in?
eis compensates from frame to frame of the video to be stabilised. this miui cam feature just uses the gyroscope to measure the angle of the phone, completely different method. of course its zoomed in cos have to rotate the photo mah, not like u can capture outside of the sensor.This technique shifts the electronic image from frame to frame of video, enough to counteract the motion.
No ext sd card alsoNo 3.5mm headphone jack.
I check official website.
Ok. Move on with my life
Next phone.
