Redmi K30 Series, Pro and Ultra
punkster
hmm in the magisk app is only cts profile failing or both cts and basicintegrity fail? if only cts fail then can try using the magiskhide props config module, can find in the hamburger menu -> downloads.
if both fail then need to revert back to china rom and lock bl.
I managed to get both to pass. DBS and OCBC works fine now though. But still can't use Citibank app. Suspect it detects bootloader unlocked. Anyway to spoof the bootloader?
Posted from PCWX using Redmi K30 Pro Zoom Edition
punkster
Since Bootloader is unlocked, easiest way to flash to eu custom rom.
All banking app and gpay will work if you using eu custom rom.
Sent from Xiaomi POCO F2 PRO using GAGT
I actually wanted to try the EU ROM but wasn't able to get it to boot up, so I chose the global ROM instead and managed to flash it using the miflash tool.
EU ROM confirm will work? Can confirm particularly for Citibank app? If yes I'll try again I guess..
NightRaven49
no need spoof bl. just go to magisk settings, then hide magisk manager. u can name the app whatever u want, apps shouldn't be able to detect it anymore. worked for me with stanchart app.
punkster
Just tried that. Sing pass app works but Citi still doesn't! Cleared all data from playstore, deleted and reinstalled the app but still being detected as root device
davidwong
Yes for me if you have magisk my UOB night app also detect it as root. Google for magisk uninstalled a uninstall.zip go to your preferred recovery and install that zip.
That will remove magisk, after that my UOB might can work Liao. So you can give it a try.
punkster
But after remove magisk will CTS fail again and other apps can't work?
bridgestonelk
Citibank app confirm can work with eu rom.
Features of eu rom:
Based on China Stable / Weekly builds (except POCOF1, HMNote6Pro, HMNote8T, HMNote9ProMax, HMNote9Pro_HMNote9S, HMNote9ProEU)
Enabled search gesture (swipe up) on the desktop
3way reboot menu (in dev settings)
Dark Mode (Night Mode) for all devices (In the dev settings except 9.x/10.x)
Removed ads in MIUI system apps
Face Unlock for all devices
Vertical clock widget on lockscreen
Steps counter in Assistant screen
More shortcuts on left lockscreen
Wake up gestures
AI preloading option in MIUI Lab
Fullscreen gestures
Option to auto-expand first notification
Notifications priority settings
More edit options in Gallery app
Enabled MiDrive in File Explorer
Added landscape mode for SMS app
Sunrise/Sunset in the weather app
Google apps support integrated
Removed 5GHz region restrictions
Confirm dials from call logs
Morning report on alarm at morning
More apps supported for AOD notifications
More styles for AOD screen
Raise to wake gesture
AOD notification received animation
Default volume control stream toggle
Tap fingerprint sensor to wake toggle
More Camera features
Double tap to lock screen
Battery AI scenes
Allowed disabling specific system apps
Importing theme .mtz from zhuti.xiaomi.com via ThemeManager
No useless Chinese bloatware apps
More free RAM due to less background processes
Unified flat style app icons for both system and 3rd party apps
Advanced menu with color icons
No any Chinese character under the full system
Mi Video, Mi Music, Mi Browser: No any useless Chinese content
No possibility to re-lock bootloader accidentally with flash any xiaomi.eu release
Added real 27 languages translation made by Official MIUI Fansites and MIUI Fans
Added EU T9 dialer support
Added charging sound switch
Added Screen-OFF animation
Optimized GPS settings for EU
Optimized Battery consumption
Optimized RAM consumption
Added 3D Touch to MI5S 3GB RAM version
Added GSMalphabet into SMS app options
Added more icons grid layout 4x5, 4x6, 4x7, 5x5, 5x6, 5x7 (depends on device)
SafetyNet passed (Google Pay)
Play Store Certified
Deodexed
Added automated tasks in Security app
Added game speed booster
Added erase module (magic elimination) to Gallery photo edit options
Fixed low volume sound via headphone
Charging screen
And more, and more made by our 9 years MIUI mods experience.
punkster
Great, I'll give it another try. Can I also confirm that other apps like simplygo is working? With Magisk 20.4?
bridgestonelk
Just tested simplygo, is working.
No need Magisk. The rom itself comes with spoofing.
minuteez
muahaha. Totally off topic but today for the first time I really looked at your name instead of just glancing and realised that its "bridgestonelk" and not "bridgestmilk" :s13:
dont ask me why it registered as that in the 1st place :s22:
bridgestonelk
breastmilk is taken so...
MrRayded
Just here to say goodbye to all the bros here hahaha I finally sold off my K30 Pro and changed to a Poco F2 Pro local set.
From weird issues like Google play services wanting to delete my contacts every time I charge my phone, apps not receiving notifications unless battery saver is turned off and lastly Google services like location history not even working, glad to get rid of my K30 Pro and I will never get another China ROM phone again.
bridgestonelk
Good for you.
But for me, k30p serve me well. Eu rom loaded with xiaomi dialer and sms app which is a plus for me. No need to use google dialer and sms app since I been using xm phone for many years.
MrRayded
Good for you.
Ya that's nice, idk why the local Xiaomi Poco F2 set uses Google dialer instead of Xiaomi dialer. Maybe 5 years ago I still got the energy to flash ROM and unlock bootloader but nowadays I just want my phone to work properly instead of messing around especially since now got banking apps
Hailgod
i think google officially dont want to allow people to record their calls, so global variant using google dialer.
xiaomi.eu is a mod of the cn miui so its not affected.
siongbb
Haha...Well said
davidwong
Haha totally agree and even then when we are tinkering we are used to those budget phone in the less than 400 bucks range. And we were to pay a pretty penny for a phone like Samsung note and iPhone back in those days we would have expected everything to work right out the box.
But nowadays seems the younger ppl really have buying power to buy a 700-1000 phone to tinker to flash rom in both xiaomi and huawei camp
hkchew03
Last time 1-1.2k can get flagship, now u need 1.4-2k to get flagship.. so no different what
Vulpix
Moderator
Moderator
Is it hard to get bank apps, google pay to work on the K30 Ultra? I read a few pages and it seems like most people having issues because no global ROM?
