Help can't decide AMD or Intel Bundle
Jimmysbc
My last rig 6 year liao.
Which Mobo + CPU bundle is better for light gaming, movie, light Photoshop and video editing.
Not going to overclock, stability and quiet important.
ITX as space constraint.
Decide on both combination because price not much difference.
Will be using the on-board GPU first and add a graphic card later.
Option1: Asus ROG Strix H470-I Gaming + i5-10400
Option2: Gigabyte X570-I Aorus Pro Wifi + 3400G
Thanks alot for the advice first.
wwenze
Why both choices 14nm...
Wait for the 7nm/10nm
xonix
If you can wait for Zen 2 apu, I highly recommend to do so. Else, rather you get a Zen 2 cpu + cheap external gpu first.
Lil_d3viLz
Can I ask why you chose x570 motherboard which costs more but bundled with a cheap cpu 3400g instead. It would make more sense to choose 3600 or higher.
wwenze
Technology never end. Is a catching up game. Is how much money you have count.
Yea and your body turns all food into shyt but that doesn't mean we shouldn't eat good food when necessary.
naked123
downgrade to b450 motherboard and get ryzen 5 3600? do you need those 'gaming' features?
gpu get 2nd hand first? rx570? rx580? gtx1060?
Audiology93
X570 + 3400G doesn't seem right lol. Maybe can save some $ by getting B550i board + 3400G or x570i + 3600 for better performance?
Sent from Samsung SM-N950F using GAGT
Jimmysbc
I chose x570 because b550 price is expensive, almost same as x570. As I need ITX due to space constraints, I want to go with onboard GPU to reduce heat and noise as the case will be beside me.
Jimmysbc
B450 board is 2 year old, I will be using for next 5 year so want newer board to last. Will be using on board GPU first so only left 3600g.
booest
AMD ... is the way to go if you want PCIE4
but if you are not bothered, intel or AMD are fine
Jimmysbc
X570i and B550i price only $20-$30 difference, that's why chose x570i.
Going with onboard graphic first to reduce noise and heat. Only will add a graphic card later when need more graphic process power.
xonix
