Apple Watch Series 5
ryan_khoo
Of course, it’s been available since Series 4, a couple of mths after it was launched.
My fren have Apple Watch Series 5.
He said Singapore cannot use the ECG function ... he said it’s country dependent and apparently Singapore cannot.
So how u use the ECG function ?
Thanks
raymondloh72
Thanks
Your friend is wrong.......Bought my watch last October and ECG function is activated at day 1.
reddevil0728
Thanks
Singapore can for a long time
Snoweagle
Thanks
That’s rubbish. I’ve been using ECG for a long time. There’s an ECG app in the watch, activated it and rest your finger on the watch crown for 30secs and you’re done.
micgoh
Hi so to run with the watch and airpods but without the phone, means I can either :
1) download the songs from Spotify and put into my watch internal memeory
2) buy esim and then stream from the watch is it?
Sorry its my first time w apple watch. Considering this or samsung watch 2 active
reddevil0728
1) I don’t think you you can. You have to have music in your iPhone music app then sync it to your watch
2) eSIM is embedded so don’t have to buy. Just need to activate
kendrick272
Got a qns on the whatsapp, not sure if this has been raised up before.
I downloaded the chatify and i can receive WA messages. But incoming WA calls not shown on the watch. Instead it will prompt a miss call notification when ended.
Is there a solution?
reddevil0728
whatsapp needs to develop an app for the watch
reddevil0728
Sian, nowadays whatsapp quite common.. Pity, series 5 still no support..
I’m not sure if it’s an Apple restriction thing on API.
It might be more like WhatsApp may not want to develop a native app.
So even if it’s series 10, might not make a difference
