Samsung Galaxy Note 20 | Note 20 Ultra
frizee
1.5 hour to get full charge is normal.
Samsung only charge at 25W.
I don't think iphone can charge faster than note.
Ah no worries, $15 lost to try out a phone is a good deal tbh.
I'm pretty confident my iPhone charges faster lol!
Actually, i might just clock 1hr40mins for a full charge.. A few posts ago, i mentioned that comparing against Youtube video, every 50sec-1min - 1%. What a joke right!? :s13:
But nvm sold liao, just come in to share and chit chat with you guys only. Probably just my luck that I've gotten a set like this. :)
Zerobim08
Turn off your phone and charge it then it will be fast. Sometimes when you plug in charger all the background updating/syncing start to run causing spike in power consumption and lower charging speed.
The Iphone 11 pro max can't be faster. It is the slowest charging phone by a significant margin.
Zakhri32
Which place reliable in helping to apply this screen protector? I don't dare apply those glue type protector myself :s13:
Zerobim08
Exynos local set: Comparing WIFI and 4g on similar usage under bright environment using 96hz VRR settings.
First image is on WIFI. Quoted reply image is 4g from yesterday. Quite a big difference in screen on battery consumption between using wifi (9.7%/hr) and 4g (14.2%/hr).
Quick calculation:
Phone Uptime: 18hrs day
Active Screen on Use (wifi) : ~7.5 hrs
Active Screen on use (4g) : ~5.5 hrs
Think for most typical usage (surf/yt/app), the active usage time should be sufficient for most people.
This morning mainly outdoor in the park, battery not so good. Maybe the high brightness and 4g are taking a heavy toll. Surfing and YT mostly. On 96hz vrr 3rd day.
Realised that the refresh rate drops to 48hz when playing YT using Samsung browser. (I don't use the YT app btw).
StationA
if want fast charge can go iQOO 5/5Pro. 120W fast charge can get your battery from 1% to 100% in 15 minutes. :s13:
DuoLeap
Quick calculation:
Thanks bro for the useful info.
My battery life quite similar to yours. 96hz on exynos. But im on medium power saving rather than your optimised mode.
The battery life is fine for me as long as it can last 6hrs.
lcheowl
https://galaxystore.samsung.com/pre...session_id=W_197a61acc183d22756b1d514295fbc22
What’s New
□ Major Fixes
- Adding Galaxy Buds Live actions and recommendation cards
- Fixing issues with disappearing manual routine widget on home screen
- Further applying additional new actions to all Q OS models (Network mode, Focus mode, Motion smoothness and screen resolution)
- Fixing other major bug issues and GUI-related issues
DuoLeap
This is the one. With stand also.
I ordered this one on Samsung online store yesterday, still haven't received it.
Going to resell it on carousel, do u think is it okay to sell it at $35 since it is brand new and sealed?
