Looking for full size 7-seaters
hermes76
Ask u all, which would u choose? Why?
1) Honda Odyssey 2.4/2.0 Hybrid(PI)
2) VW Sharan HL 2.0
3) SEAT Alhambra 2.0
4) Mazda CX9
5) Kia Sorento
Or any other u can recommend? Budget ~160K
Thanks.
Sent from HUAWEI EVR-L29 using GAGT
Advancer
Nissan Serena e-power is a value for money car if you ask me. I tested it and love it but not time for me to change car yet.
hermes76
I've seen it during their launch, dun quite like the design, SO also dun like, therefore those Noah, Voxy, Espire all not included.
sky00sky
vellfire near ur budget
Serena really not bad
In your case must ask urself how often need the 7 seats.
And weigh wat is important
Full size boxy mpv vs suv with third row seats
pawn_king
not a recommendation, but you can look at maxus G10.
For the $, can't beat its space. 7 or 9 seaters with generous boot space left.
hermes76
This 1 overkill, SO not keen on loti chia.... �
myviowner
TS ar TS... You will get even more confused. Seen many that started similar topic. lolz.
Anyway, good luck to your car hunting.
sky00sky
Build not good la
My company vehicle in China is the G10 electric
Make no good
Bam25th
Only the Estima but I find it ex n dated.... Alphard/Vellfire out of my budget le
Vellfire PI is actually cheaper than some of your options.
I was looking for a 7 seater too, and in the end, picked Sienta cause my Budget even much lower than yours haha
sinistral
Not sure if the new SPF Fast Response Car share parts with the 7-seater Kia/Hyundai models, if so, the Korean makes may be attractive as it may be cheaper to maintain.
focus1974
2) VW Sharan HL 2.0
4) Mazda CX9
5) Kia Sorento
Thanks.
7 Seater!
Best type is the sliding door ones.... and you can stand inside type
So my choice will be...
1) Toyota Noah
2) Toyota Previa
3) Mazda Biante
4) Toyota Vellfire/Alphard (too big .. like driving minivan)
gohsj89
2) VW Sharan HL 2.0
4) Mazda CX9
5) Kia Sorento
Thanks.
How is CX9 within your budget?
Get the odyssey la!
For me I love it!
The space, not too big, not too small.
Sliding door..
sky00sky
Odyssey seems good if last row no need for adults
Else is short distance locally no need boot space .
hermes76
OK tmr going test the Odyssey 2.4. I like the 2-2-3 seat configuration. Downside gonna be the roadtax....
