iOS 14.0.1
TrueBeliever_jh
widget size too bad cant change~
i only got 2x Shortcut (from SafeEntry), so the best Shortcut widget i think is the one with 2x2... i got 2x blank space~ :s13:
PongRareRare
What is this “find and connect devices on your local network”? What does it do exactly?
FeNgZhEnG
still waiting for ios14 update to appear on my XR:(
tec_geek
ya this keeps popping up when opening certain apps
If I’m not wrong it is a new privacy feature on iOS 14 when an app uses your local network so that it can or not to be found or identified?
https://developer.apple.com/videos/play/wwdc2020/10110/
ragnarok95
Senior Moderator
Senior Moderator
Now deep fusion is supported on view outside the frame.
xtwis7
Do you all find it annoying after you copy/paste something the banner pops up. And Hwz app seems to be having a issue where it remembers one of the copy from Facebook so no matter what everytime I open hwZ, the banner appears.
ragnarok95
Senior Moderator
Senior Moderator
When connected to APP, every time u unlock your phone there is a small pop up on top of the display state APP connected. Anyway to remove this?
ringrain_78
1 questions - for the widgets, there is a very limited number of available widgets, right?
Not all widget can added into the smart stack, right?
Am i doing it wrong?
I am missing my Strait Times app in my iphone but it's available in my ipad.
Overall, I think smart stack is cool if they allow more widgets.
PetPet
Moderator
Moderator
this means that the HWZ app is attempting to read your clipboard whenever you open it.
it's a bug. this should not happen, and HWZ should fix this.
