- Sep 16, 2018
I think that one not me..
I do not have the issue with the signal.. It seems the android box spec is not that great..
Thanks.. will try to search for memory cleaner in google apps store.
I see. You can run AIDA64 to check out the CPU/GPU configuration. That would be an interesting info.
I tend to think it is more an optimization issue. Not so sure which company is the OEM behind.
Mi Box S has pretty low end Amlogic S905X CPU but the optimization by Xiaomi is pretty good. So it is pretty smooth at 1080p 60Hz, okay at 4k 30Hz, but may not as smooth in 4k 60Hz.
Maybe you can check if the Starhub TV+ box becomes more smooth if you set the screen resolution to 1080p 60Hz or 50Hz.
