AMD Ryzen NB Discussion| Lenovo Thinkpad E495/E595/T495/X395 Well-rounder performance CPU + GPU
Phrajile
actually i'm wondering.
For Legion 5, the site allows up to 16GB (8x8) but this means if want 32GB, must buy 2x16GB and replace.
If that's the case, might as well just order 8GB Legion 5 and save on the 8GB 2nd stick since gonna upgrade anyway.
Makes sense?
flowerpalms
Makes sense?
16gb alot alrdy
Posted from PCWX using SM-G973F
Mystyque
Makes sense?
that is what I would do and did with my thinkpad
Mystyque
That's what I thought also, and if I have enough RAM, then I won't need to worry so much about setting pagefile settings on the SSD.
I dropped in a 32GB sodimm total 40GB because 8+16GB would be too little though :o
kimsix
Try IPRICE30
Thanks bro, seems to better on some units
Anybody critique this yoga thinkpad 13.3" around $1K, as a cheap Surface alternative, or should go for ipad 12.9?
kimsix
128gb ssd only?
oh ya wanted to try compare surface or ipad since they generally 128gb.
but i've changed back to 256gb, only extra $21. :o
though not sure if need 256gb for pure docs work and media consumption while zooming. =:p
hardwaregone
For E and L series...
E series is an entry-level, while L series is a Mainstream wannabe
Lenovo created two different products which are similar in so many ways, I really dunno which one to recommend lolz
Here's a few things I can suggest for comparison
1) E series is like the lowest of the Thinkpad. L series is 2nd lowest but it is targetting Garment, enterprise and Education whereby weight and size not really important factors.
that's why L series have features like LTE, mechanical docking, Smartcard reader, as found in the more expensive T series, just in a thicker, less expensive plastic package. But it's weird that E series has better build material
2) both ram slots in L series are not soldered. So it's possible to upgrade. E series. One slot soldered, 2nd slot upgradeable.
3) $80-100 for an additional 8GB??? It's better you buy the ram separately and upgrade DIY
Sent from Henabi virus using GAGT
I did a config for both L14 and E14 on Lenovo's website, using Intel Core i5-10210U Processor ( 1.60GHz 6MB ) .
E14 seems to be more expensive than L14. Why?
omfgitzahbuneh
bought a T14 AMD Gen 1
Processor : AMD Ryzen 7 Pro 4750U Processor (1.70GHz, Max Boost up to 4.10GHz, 8 Cores, 8MB Cache)
Operating System : Windows 10 Home 64
Operating System Language : Windows 10 Home 64 English
Memory : 16GB DDR4 3200MHz Onboard
Total Memory : 16GB DDR4 3200MHz Onboard
Hard Drive : 512GB Solid State Drive, M.2 2280, PCIe Gen3x4, OPAL2.0, TLC
Display : 14.0" FHD(1920x1080) WVA Anti-glare 250nits Non-Touch Narrow
Graphic Card : Integrated Graphics
Camera : 720P HD Camera with Microphone
Laptop finally shipped out ytd, manage to cancel and purchased the same specs during sales, saved additional 300SGD, damn heng
limlg73
hi, may i know where to get this at around $1k? I checked Lenovo Online, it is much more expensive than $1k...thanks.
Phrajile
ThinkPad L13 Yoga
$1523.90
-$452.70
Final: $1071.20
Processor : Intel Core i5-10210U Processor (1.60GHz, up to 4.20GHz with Turbo Boost, 4 Cores, 6MB Cache)
Microsoft Productivity Software : None
Memory : 16GB DDR4 2666MHz Onboard
Hard Drive : 128GB Solid State Drive, M.2 2242, PCIe-NVMe, TLC
Display : 13.3" FHD (1920x1080), IPS, Glare, 300nits, Multi-touch
Color : Black
Pen : ThinkPad Pen Pro
Fingerprint Reader : No Fingerprint Reader
Keyboard : Keyboard Black English
Wireless : Intel Wireless-AC 9560 2x2 AC, Bluetooth Version 5.0 vPro
TPM Setting : Enabled Discrete TPM2.0
Absolute BIOS Selection : BIOS Absolute Enabled
Battery : 4 Cell Li-Ion Polymer Internal Battery, 46Wh
Power Cord : 45W AC Adapter PCC (3pin)-UK (USB Type C)
Display Panel : 13.3" FHD (1920x1080), IPS, Anti-Reflection, 300nits, Multi-touch, 720p HD Camera, Aluminium, Glossy Black
Language Pack : Publication-English
Warranty : 1 Year Carry-in
3Y Onsite upgrade from 1Y Depot/CCI
