New rig - will it meet my needs?
jack-320
Hi all
Went to dynacore today
I asked for a $1,500 rig that can play game
he gave me these recommendations:
CPU: Ryzen 5 3600
Motherboard: GIGABYTE B550M AORUS ELITE $472
RAM: KLEVV BOLT X 3200MHz CL16 (AMD) 16GB $95
GPU: Galax GTX1660 Super 1-Click OC 6GB Twin Fan GDDR6 $325
SSD: Samsung 2.5"860 Evo $115
HDD: Seagate Barracuda $139
PSU: Seasonic Core GM-550W Semi Modular $117
Case: Tecware Nexus Air Tempered Glass casing(4Fans) $65
Total cost: $1,328
Because I don't know ask him question like whether can play cyberpunk 2077 at 60fps, so I focus on budget first
So for this spec it is sufficient? or I need to increase to few hundred to play comfortably
*I can wait until end of this year when new Ryzen comes out
*yes I did check PC Rig Recommendations by MoneyFace beforehand
jack-320
Just wait for new cpu and gpu releases this month? Coming real soon
I can wait actually
But I am not very good at specs
as in whether it will play at 60fps flawlessly
Hence asked them as a guide first
XseanX
I can wait actually
What resolution & game graphic setting you are looking at? Gpu wise spec wise look abit low if want to game at higher resolution like 1440p and high setting. Anyway as per others have advised, do wait and see what Amd offering for their next gen cpu & gpu first.
jack-320
2560 x 1080 (widescreen), otherwise 1920 x 1080 is ok
Graphic setting at high, no need to be ultra high as it will require RTX 3080 which exceeds my budget
Yeah as per others' advise, I will wait for their next offering for their next gen cpu and gpu
jack-320
Cyberpunk 2077? Maybe if you play at 720p.
Huh
at 720p
seems like I need to increase my budget?
I wait for the new gen to come out first...by then the recommendations will change
Rashkae
Huh
at 720p
Yeah especially the GPU is basically low-end. The CPU is the lower end of mid-range.
You might get away with 1920x1080 at medium settings.
NightRaven49
r5 3600 is a strong cpu and wont bottleneck ur gpu. 1660 super is also competent, on 1070 performance level, should be able to sustain >60fps on 1080p ultra on most games. if looking for 1440p then will need upgrade to say an rtx2060 or better. as for cyberpunk 2077, it hasnt even released so cant say for sure if the 1660 super can handle.
however, do wait for zen 3 to arrive to see if there are better value offerings before buying anything. i dont think there will be much new things on the mid range gpu front so buying ur 1660 super now wouldnt be risky.
other things i would recommend u change are the ssd and case. for ssd u can consider getting a nvme drive, even good quality dramless ones. they will be significantly faster than a regular sata 2.5", think a few thousand MB/s read and writes. also do consider switching the case for a better one, the nexus cases are cheap but the airflow is bad and the quality is so-so (speaking from experience); perhaps the coolermaster nr400 or silverstone ps-15rgb will do the job better, especially since ur building with a matx mobo.
tigerwoods
Cyberpunk 2077 System Requirements
Please note that the game is both graphics- and processor-intensive, so make sure these components meet or exceed the minimum requirements. Also note that the minimum is created with Low settings and 1080p gaming in mind and Recommended with High and 1080p.
Minimum requirements:
OS: 64-bit Windows 7 or 64-bit Windows 10. DirectX® 12 is necessary to run the game.
Processor: Intel Core i5-3570K or AMD FX-8310. Finding a CPUs performance hierarchy chart or comparison website and comparing one's CPU with our minimum is suggested.
Graphics: Nvidia GeForce GTX 780 3GB or AMD Radeon RX 470. Finding a graphics card performance hierarchy chart or comparison website and comparing one's video card with our minimum is suggested.
RAM: 8 GB
Disk space: 70 GB HDD (SSD recommended)
Recommended requirements:
OS: 64-bit Windows 10. DirectX 12 is necessary to run the game.
Processor: Intel Core i7-4790 or AMD Ryzen 3 3200G
Graphics: NVIDIA GeForce GTX 1060 6 GB or AMD Radeon R9 Fury
RAM: 12 GB
Disk space: 70 GB SSD
Lil_d3viLz
PM me at the end of the year. I'm looking for an upgrade as well.
I'm looking for the cheapest price too.
CPU: Ryzen 5 3600
(3600 or 3700 is good. 4000 series might be better)
(Since you are more of a gamer, have you consider RTX3060/3070 or Navi 22/23)
(Do consider getting 1TB Gen3/4 NVMe SSD will do)
(I would advise you to get better PSU. Gold / Platinum / Titanium)
(Chassis is more of personal preference as long as Airflow is ok)
Goodshot
Rtx2060 is selling 399 now ,don't think 1660s still worthy for 300+
zmallwood
Bro PSU better get 750W or 850W gold, spend abit more for PSU is worth it.
CPU and GPU can wait for the upcoming AMD announcements if you're not in a rush.As some have suggest for GPU, RTX3060 OR 3070 is good.
chaoprokia
Mine Good brought last year.
Tune according to your liking.
destiny88
CPU: Ryzen 5 3600
huh what stuff u on, Seasonic core gm-550w is gold cert ah, and its almost 99% comfirm its 5000 series for AMD cpu.
i have used it to run a OC3600+2070s OC before.
if hes looking at 1.5k, its a good choice already. and a 1TB pcie ssd will push him out of his budget.
Lil_d3viLz
1TB SSD is ~$300 or less? 500gb if he wants it <$200. Unless he is gonna use the full capacity of HDD. Then no choice.
There are people with SSD w HDD combo, they can't even finish the SSD space. HDD is like a few GB outta TBs of capacity.
Sorry. But 550W? I thought most will recommend at least 750W? More room to work with in the future.
