Is LUMOS Home Cinema Projector worth buying?? Really tempted to order nao!!
N4E.SI
Any buddie bought aldy? Is it worth the $299 :s12:
I really tempted to buy one for my room :s22:
N4E.SI
Guys have a really noob qns here - what's the diff between the regular vs smart version?
I know regular means u have to connect via HDMI to your laptop, basically it just projects whatever ur laptop is playing
Smart version has built-in youtube/netflix means what/ Dun need connect to laptop at all??
Then how u type in or search for movies on youtube? The projector got keyboard meh
virtualape
the smart is wifi with apps installed. think a keyboard will pop up to enter with the remote control.
if you are connecting to a laptop or pc, just get the non smart version will do. save that $49.
theres another brand with the same specs. i think they have a physical shop to see the demo. slightly cheaper. https://beamerx.sg/collections/projectors
it looks the same to me. im tempted to buy but yet to figure out a way to place the projector without getting in the way.
{jarvis}
Previously i think someone here posted a aliexpress link on the OEM of lumos...
Sent from HUAWEI VOG-L29 using GAGT
N4E.SI
Ahh thanks for the detailed explanation! Actually I havent figured out where to place too lol. My room kinda small and dun even have a entire white wall to project
But was thinking can also bring to fren house for movie party or staycations etc
megabyte14
Just get the normal ones will do
The smart ones with built in apps are slow af and so much more expensive
virtualape
Btw smart version is plus $99, not $49 :(
wah the price went up ah. i remember was $349 for smart and $299 for the stupid version. seems like more stupid people are buying the smart version.
JivBunny
What’s the lumens rating? Contrast Ratio?
Some of these so called projectors are only good if u have a near pitch dark room.
FINE_01
Still need to preorder. Somemore seriously real native 1080p??
Joey5555
Was considering this, but end up bought Xiaomi Youth Projector (Global version) on Qoo10 with 10.10 coupons. No regrets.
elimmel
i bought the smart version for my study room. downloaded singtel go app and now can use like a smart tv.... just bigger screen.
Stuffed
How much you got the Xiaomi? The price difference quite alot compared to the Lumos.
Joey5555
There's a group buy in qoo10 at $550. Used a coupon, reduced to about $500, then got another $10 cashback for using standchart card.
It's still more expensive but you get Android TV 9 compared to version 6 on the Lumos. Has auto focus which I felt was very convenient. Pictures are sharp and bright, and speakers are loud enough though I felt they could do with more bass.
Testing it out:
AMquxh0.mp4
