German CECA-ed IT firm SAP stock crashes almost 17% in a day as prospects dim
cutekawaii
Salesforce India. Salesforce is CECAed and no one is pointing that out. In the end, point me one AMDK Global ICT firm without CECA. Don't pick on SAP.
who still uses SAP? I thought everyone is salesforce liao
addict951
High Honorary Member
I tell y’all hor.
I worked in this company everyone’s phone lines are tracked & costed in SAP. Very zhun one. I chua tio
So ar, how many mins you spend on the phone daily the boss click a few buttons can see liao. :crazy:
Then ar, photocopier you use how much paper also tracked in SAP. :o
cutekawaii
I have worked in this company too. Engineered by Germans tell us a lot on the quality of SAP.
I tell y’all hor.
tatsit
I tell y’all hor.
that's only if the company bothers and they hire competent people, i believe to set up the process workflow is a competency by itself.
normal office aunties see SAP, they think they know very well, but what they are doing is just data entry.
die
Yes depend what the coy use sap for ba
setup that time is veri important ...
One thing i dont like abt sap is their automation part is cmi, have to do and run external scripting
Their internal scripting and recording is real cmi
Shutterbox
Is the problem with the software or the ppl implementing?
I tot sap dun directly do implementation?
addict951
It’s usually user problem. :o
You can buy SAP vanilla as it is mah.
But most companies will have some form of customisation involved.
All implementations got problem one, cos of the various functions involved.
Asphodeli
For the amount of $ a company can throw to SAP, one can hire a software dev shop to code it out for you for far cheaper, better and faster :s13: :s22:
saycheese
i only know the CECA attached to my coy to help out with SAP always cock up de :(
miketay90
if german cars are anything to go by, german products are over-engineered to the extent of causing reliability issues
