Oneplus phone worth buying?
c4765177
From the OnePlus 8pro thread got a lot of problem with Google pay. Is your one ok? I was considering it but this is a deal breaker for me
recall the main complaint with 1+8pro is the green tint,
dunno isit solved yet...
Mclairs83
still using oneplus 7 pro. still very snappy since day 1.
maybe i don't have any intention to change this year. and this will mark the longest phone i ever own laio.
most my phone don't even last 1yr.. after a year i will just sell away. :s13:
Now my OP7 Pro it's 1yr 4mths of ownership already.
lifeafter41
using oneplus 8 pro since 2 months ago, change from s10+
nv looked back, oneplus 8 pro is much faster, snappier, screen looks sick , and alot of cleaner in the OS.
and best! only $1000 without contract
Where did you buy it?
Understand it’s dual sim?
kiryu86
I'm using op7 and really like it!
This is the best phone I've used after so many phones. Camera is the biggest flaw only. Heard Op8pro has up to standard camera but I've not tried it personally
yes, camera has improve alot,
the display is so much nicer than samscam, and best thing is,
can set it at 1440P QHD + 120 HZ together!!!!!
samscam cannot even do that!! i also duno why sia! so expensive phone yet cannot perform he latest tech
kiryu86
I noob here. Quick question, for dual sim, can use different telco?
yes u can,
can do the switch inside.
like go overseas. i use dual sim also. i just put in the overseas sim card into sim 2, then start using it liao. i just turn off my sim 1 local card. then activate sim 2 card.
bigboo
Using OP6 for two years. very good phone for me.
comparing with my previous Samsung and xiaomi.
i wont say ITS THE BEST PHONE. but enough for my standard.
If this phone die on me, i will get another Oneplus.
But there are many ppl who does not know about Oneplus.
lifeafter41
yes u can,
Got it.
Thanks!!
Pocoyoz
Sent from Amazon using GAGT
siduki
Have they fixed the Google Pay issue on local sets? And is Volte enabled by default now? Last time need to tweak some settings to enable Volte
c4765177
they've lost their way a bit since 1+6
i have a 1+6 too.. it was the cleanest and closest to android stock...
in the newer versions (1+8 onwards) they start to preload bloatwares (FB and Netflix, never know what they will load next time) and force you to install certain apps (oneplus buds, which you cannot uninstall after installing)....
they are now pushing the up and coming Nord 10 and 100, which is just a bloody repackaged Oppo phone that's already existing...
cwchee
Had been using Oneplus 5 until recently when the screen gave way.
already placed order for Oneplus 8T mainly due to the 65W dual battery fast charge.
Oneplus Oxygen OS is one of the best out there other than vanilla android.
not much bloatware as compared to xiaomi or samsung.
Runs just as fast since day one even after using 3 years.
The longest phone i had in possession
AlwaysHardAlwaysReady
Just bought 1+7T..
Love the flat screen..
But there is an issue where I unlock my phone using fingerprint.. the notification bar missing and not responsive.. need to re unlock the phone again..
Anyone have this issue on 1+?
kiryu86
From the one plus thread, looks like very problematic.
Don't work flawlessly
apart from gpay, everything is flawless.
i use samscam, iscam , huawei , xiaomi , LG before
and oneplus is already winning my trust.
how did i miss out this brand in the past?
pushtopen
Still using one plus 6, just received oxygenos and security update last week. One plus phones can use very long. At least 3-4 generations before considering changing. Phone still going strong for me.
Sent from OnePlus ONEPLUS A6003 using GAGT
