Oneplus phone worth buying?
hyzhenry
I also considering oneplus for mu next phone. They releasing oneplus watch also. Will hoot both to go together.
Sent from HUAWEI LYA-L29 using GAGT
delfina
using oneplus 8 pro since 2 months ago, change from s10+
nv looked back, oneplus 8 pro is much faster, snappier, screen looks sick , and alot of cleaner in the OS.
and best! only $1000 without contract
Carrot head spotted buy this brand at $1000 and still so happy :(
lifeafter41
yes u can,
can do the switch inside.
like go overseas. i use dual sim also. i just put in the overseas sim card into sim 2, then start using it liao. i just turn off my sim 1 local card. then activate sim 2 card.
Oh, 1 more question.
Is the OP8 pro dual sim, the active type?
Meaning able to receive call from either line, at any one time?
Thanks!!
Tony_Chua
if you looking at budget phone like oneplus nord, better get pixel 4A. cheaper and better camera.
kiryu86
did u even bother to read the entire spec of the phone?
if u r buying for the branding, then pls shove off.
since ur just a typical sheep then follow the "trend" and has no own perspective n opinion. monkey see monkey do.
:s13::s13:
kiryu86
Thanks!!
i have nv tried that before.
but the spec stated as Dual SIM (Nano-SIM, dual stand-by)
means both sim card can run simuteneously ?
kiryu86
Anyone knows if 1+ has a lot of bloatware like xiaomi?
its actually the most minimum n clean OS i have seen or used,
and that explain the fast boot up and snappy lag free after so long of usage as per decalre by some of the user here since oneplus 6
PiPiChew
OnePlus 7 Pro user here from Aug 2019.
Pros:
Full screen 0 bezel no hole punch camera or notch (pop up front camera)
Amazing screen
Excellent battery life
Very clean UI. Not much bloatware, thus very speedy when paired with Flagship Snapdragon
Cheap cheap below 1k
Cons:
Not sure if support will be here after 2 years or not. But so far the updates are quite regular
Casing hard to find. This kind of phone when you buy upfront go hoot all the casings you want as spare.
Sent from A Young Urban Professional Who Is Highly Sought After By At Least 3 Companies - Telco, Utility And Credit Card using GAGT
aspenco
Nice. Ty. So it's like pixel. 2 of staff highly recommended pixel cos it's not laggy as it has very minimal bloatware. Ty.
ninefile
If want 0 bloat should get 7 and older ones....
If u can take fb and Netflix preinstalled then can get 7 and newer....
Posted from PCWX using No. Blank. Cheque!
