Oneplus phone worth buying?
tatsit
High Honorary Member
I'm using OnePlus 6
Most likely waiting for OnePlus 9.
Reviews for 8T seems to suggest it is not worth
Richliao
using oneplus 8 pro since 2 months ago, change from s10+
nv looked back, oneplus 8 pro is much faster, snappier, screen looks sick , and alot of cleaner in the OS.
and best! only $1000 without contract
Anyway to still take xray pic?
kiryu86
What’s the specs ?
NETWORK Technology
GSM / CDMA / HSPA / LTE / 5G
LAUNCH Announced 2020, April 14
Status Available. Released 2020, April 21
BODY Dimensions 165.3 x 74.4 x 8.5 mm (6.51 x 2.93 x 0.33 in)
Weight 199 g (7.02 oz)
Build Glass front (Gorilla Glass 5), glass back (Gorilla Glass 5), aluminum frame
SIM Dual SIM (Nano-SIM, dual stand-by)
IP68 dust/water resistant
DISPLAY Type Fluid AMOLED, 1B colors, 120Hz, HDR10+
Size 6.78 inches, 111.7 cm2 (~90.8% screen-to-body ratio)
Resolution 1440 x 3168 pixels (~513 ppi density)
Protection Corning Gorilla Glass 5
PLATFORM OS Android 10, upgradable to Android 11, OxygenOS 11
Chipset Qualcomm SM8250 Snapdragon 865 (7 nm+)
CPU Octa-core (1x2.84 GHz Kryo 585 & 3x2.42 GHz Kryo 585 & 4x1.8 GHz Kryo 585)
GPU Adreno 650
MEMORY Card slot No
Internal 128GB 8GB RAM, 256GB 12GB RAM
UFS 3.0
MAIN CAMERA Quad 48 MP, f/1.8, 25mm (wide), 1/1.43", 1.12µm, omnidirectional PDAF, Laser AF, OIS
8 MP, f/2.4, (telephoto), 1/1.0µm, PDAF, OIS, 3x optical zoom
48 MP, f/2.2, 14mm, 116˚ (ultrawide), 1/2.0", 0.8µm, PDAF
5 MP, f/2.4, (Color filter camera)
Features Dual-LED flash, HDR, panorama
Video 4K@30/60fps, 1080p@30/60/240fps, Auto HDR, gyro-EIS
SELFIE CAMERA Single 16 MP, f/2.5, (wide), 1/3.06", 1.0µm
Features Auto-HDR
Video 1080p@30fps, gyro-EIS
SOUND Loudspeaker Yes, with stereo speakers
3.5mm jack No
COMMS WLAN Wi-Fi 802.11 a/b/g/n/ac/6, dual-band, Wi-Fi Direct, DLNA, hotspot
Bluetooth 5.1, A2DP, LE, aptX HD
GPS Yes, with dual-band A-GPS, GLONASS, BDS, GALILEO, SBAS
NFC Yes
Radio No
USB USB Type-C 3.1, USB On-The-Go
FEATURES Sensors Fingerprint (under display, optical), accelerometer, gyro, proximity, compass
BATTERY Type Li-Po 4510 mAh, non-removable
Charging Fast charging 30W, 50% in 23 min (advertised)
Fast wireless charging 30W, 50% in 30 min (advertised)
Reverse wireless charging 3W
MISC Colors Glacial Green, Ultramarine Blue, Onyx Black
Models IN2023, IN2020, IN2021, IN2025
Price $ 728.99 / € 748.00 / £ 607.61
TESTS Performance AnTuTu: 573276 (v8)
GeekBench: 3374 (v5.1)
GFXBench: 24fps (ES 3.1 onscreen)
Display Contrast ratio: Infinite (nominal)
Camera Photo / Video
Loudspeaker -23.5 LUFS (Very good)
Battery life
Endurance rating 103h
gtreds
Been using oneplus since oneplus 3 then oneplus 5t and now oneplus 7 pro.Very fast software but downside is camera performance which can be solved by using gcam.There are other small imperfections but i'm still quite happy with it,waiting for A11 update.
Software support i think only 2years,after that no updates anymore.Why i know?It happened to my oneplus 5t.No new updates already.
hardwaregone
Read the thread that people wipe liao can use the google pay, can confirm?
Will it affect banking apps?
Then if there's a new update, will the problem return? :(
gtreds
Forgot to add now that they have 3 variants of the phone instead of just one flagship per launch,they kind of need to cut corners for different grade phone and i think they haven't get to grips of what to cut and what corners not cut.
Shdwfalcon
If you can overlook the lack of external sd card slot and headphone jack, then yes, it's a great phone. Oxygen OS is a close to stock as a non-stock OS can get from any android phone manufacturer.
aspenco
If want 0 bloat should get 7 and older ones....
If u can take fb and Netflix preinstalled then can get 7 and newer....
Posted from PCWX using No. Blank. Cheque!
I googled 7t and somehow it showed me a few site from india. Wtf. Lol.
But thanks.
ninefile
But thanks.
bro you do know that oneplus brand is very popular in India ba?
India is their biggest market for now....
ninefile
sorry but it never appeal to me how come so many people rely on gpay....
isit really that useful?
Ev0d3vil
Just saw the co founder left the company? How will this affect the direction of the company? Merge with Oppo?
kiryu86
yes, u basically no need bring out credit card and ezlink anymore.
all use gpay to tap n pay n go.
super convenient, life changing experience
ninefile
But not everywhere accepts gpay right? Means u still need cash as backup?
aspenco
I think it isn't just one plus or china made cellphones per se. Most of the chinese products have been very popular in india.
xllms
Moved from iPhone6 to Oneplus 5 then late last year upgraded to Oneplus 7pro. Love the OS, dual app is a big plus (one for personal one for work) To me everything is good except camera which cannot match competitors' quality.
xllms
i have nv tried that before.
but the spec stated as Dual SIM (Nano-SIM, dual stand-by)
means both sim card can run simuteneously ?
On Oneplus 7pro, using dual sim concurrently. Can switch data received, call/msg in/out easily in the settings.
aspenco
I just realized 1+ 7 and 8 doesn't have sd card slot... Or did I see wrongly? :(
cwchee
As long as they accept paywave, can use phone to pay.
Alternatively, can use grabpay or other payments that uses the QR code for those hawker center. so technically, almost no need to bring cash out
