Oneplus phone worth buying?
twisti
Oppo SG (Sinoppel Device Pte Ltd) has taken over as the distributor and servicing of oneplus phones from 8T onwards. Finally oneplus has a proper service centre
Campbellsoup
Oh, 1 more question.
Is the OP8 pro dual sim, the active type?
Meaning able to receive call from either line, at any one time?
Thanks!!
speaking from oneplus 7 experience... you can do that. I have two sim cards in my oneplus7 now... both are active for voice calls but my data is on the first sim card only. once i use finish data on the first sim card i will switch over to use the data on the second sim.
both are doable.
amazingone
I just realized 1+ 7 and 8 doesn't have sd card slot... Or did I see wrongly? :(
All along from OnePlus One to the latest OnePlus 8T don't have micro SD slot.
Only their budget OnePlus Nord N10 and N100 have micro SD slot.
Posted from PCWX using HUAWEI ALP
ineser
Moi 1+7T one year. Still quite fast and the updates also comes in quick often
Posted from PCWX using HD1900
Nevereatrice
Curve screen
Local sets have gpay problem
Exports sets no warranty at $1000
Some sets have display issues like black crush so it's a lottery
Battery life not sure if 120Hz hurt it by how much
$1000 for this depends whether u can accept. For me is no. $1000 No warranty is no
amazingone
No longer distributed by Mister Mobile?
ninefile
Curve screen
1+8
no issues on display
no use gpay
i paid less than 800
Campbellsoup
to answer TS questions... after trying out almost all brands of phones around i personally feel oneplus is cleanest and easiest to use after iPhone. iOS is nice and had been my daily driver for most part of my 20s but it just grew so expensive and the value / worth you get is not there anymore. oneplus fits my usage and i don't need the camera to be the best.
changed from iOS 2 years back after like... 6-8 years from iPhone 4 - 8 to oneplus and the value for specs i get is great! i love my phone and it is not slow after close to a year and a half. am getting older too and don't think i will be changing phone every year to two like i used to and probably will stick to my oneplus 7 till it dies and get another oneplus. didn't like the xiaomi, oppo, realme, samsung experiences.
KnightDroid
Ask u then, got try vivo? Iphone still overrated for its price, cannot even protect itself from fall.
Ecosystem definitely andriod cannot compare, not at same level.
I am a specfication person.
Campbellsoup
vivo i didn't... my mum in law uses that and i had tried it only a for a bit + troubleshoot some issues with lock and unlocking the device. Haven't used it like everyday. Can't really comment for this as daily driver but generally the short experience with vivo phones is that it didn't feel smooth. :(
KnightDroid
Means processing and graphic still bay zai lor.
Huawei mate40 from vlogs, camera stability not as solid as advertised. Samsung mostly got heat issues.
Overall the ultimate hp have not appeared yet.
Means whatever old phone we have now, change the battery, continue to watch ba.
twisti
Ya, Oppo took over local distribution of Oneplus. The authorized service centre now is Oppo Suntec. Previous models can still be serviced at Mister Mobile
