iPhone 12 Series
limmk
iPhone 12 Teardown Internals Wallpaper
iPhone 12 Teardown Internals Wallpaper (Low-contrast edition)
iPhone 12 X-ray Wallpaper
iPhone 12 Pro Teardown Internals Wallpaper
iPhone 12 Pro Teardown Internals Wallpaper (Low-contrast edition)
iPhone 12 Pro X-ray Wallpaper
argentinafa
When I woke up this morning and look at my daughter's phone, her MagSafe stopped charging at 76% coz it was too hot. I switched over to normal lightning charger for her.
Tonight will monitor again, maybe she put her iPhone below her pillow hence aircon couldn't cool the charging process. Using Apple silicone case.
Will put MagSafe and charge overnight again tonight but with phone above pillow.
Kinda defeat the purpose when they all students have a full day in school with CCA, they need 100% phone to begin with and hence can last till full day 5pm.
Not like we all office ppl, have charger to charge in office.
MagSafe doesn't give the safe sense of security lor.
Going forward, how to give consumers the confidence that future iPhones will be portless.
Can't be at night when charging, must take out phone from casing to prevent overheating. Morning put in again.
Edit: Aircon room temp set at 24deg.
szeli
student at school need to be on their phone e whole time? 🤔 put below pillow expecting it not to get hot?
Fellowes
Better not to have phone on the bed or under pillow when sleeping or charge on bed.
Time to sleep, put phone on table and let it charge. Haha just saying.
Same logic, use laptop on bed and expect it not to be hot, of course it will heat up as it block the vents and air flow when put directly on bed. Under pillow so dangerous in terms of fire hazard, trap heat plus also bad for body.
argentinafa
Yup. Not good for battery health % if every night battery gets heated up excessively.
Last time is using 5w lightning port charger, put under her pillow charge no prob.
Put hp under pillow is to prevent her hand accidentally smack the hp till it drop onto the floor, if it was above her pillow.
Shall change her habit and put it to charge on the table.
007Mi6
Radiation and electronics try not to put too near body at night. Best off course switch off or else place it 1m or more away
NottiPanda
Yep not good to put under pillow in case get over heated and start electrical fire. And of course they always say not good for developing kids to have charging electronics next to them when they sleep. I’m using the 5W cable, charges pretty fast actually, the phone doesn’t get heated up.
tikokia
will putting a Glass camera lens protector affect the performance of the cameras?
is it worth it as it will protect the lens from being scractched?
btw where u guys download ur wallpapers from? any recommendations
kruzeryo
Camera Lens protector will affect the performance. Photos will have some glaring.
nexusscion
You are lucky the phone never explode if under pillow. There is no room for the heat to transfer out. Possibly other phone or charger will not able to auto cut off power and catch fire. Be safe. The MagSafe should put it on the even table or at least with a fan blowing underneath. Apple possibly should come with a stand to insert the MagSafe with cooling fans
spidercyj
You bought an iPhone 12 Pro for your daughter?😱
argentinafa
Tks all bros for your input. Appreciated.
My daughter needs her hp near her as she has a habit of snoozing her alarm during sch days. Snooze several times.
Will try tonight to charge for her with phone away from bed, nothing covering the phone, with MagSafe facing upwards instead of phone screen facing upwards during night charging.
