Xiaomi TV Discussion Thread VI [consolidated]
gregory_choo
People who use Android handphone will find it easier to adapt to Android tv interface. It is the flexibility to do more that makes it more lively. 65" is a good choice given that most buyers find its colour good and acceptable at this size. Bigger size more enjoyment! :)
not really.
android tv os is very different from handphone's android user interface.
in fact many people have problem getting used to android tv os.
but after a while they will find it easier and better to use on tv. although there are some who can't be converted and always ask for web browser, keyboard and mouse (android tv os discourages the use of these).
GJN
not really.
Google Play, apk application installation, custom rom etc. are what I think of as similarity. True enough when you go into details, there are quite a lot of differences between the two. Different people will adapt to it differently.
Teo Ming Ern
not really.
Many sideloaded apps don't play nice with a tv remote controller leh... YouTube Vanced is one of those... otherwise, VLC & Kodi are great!
Teo Ming Ern
Anyone can help with Photoguru? I'm trying to set up a SMB sharing from my PC... it works for VLC & Kodi quite easily but I always get bad user name or wrong password error message... I'm accessing the same PC and main folder on the PC as VLC & Kodi... confused... definitely a noob at this... if can help, please drop me a PM... thank you!
gnixer
If u switch off not standby then no need re-pair again
Always need to re-pair my BT headset after I switch off the TV and turn it on the next day. It used to be able to recognise the headset just as my notebook would. Any ideas?
fromnuaa
Mi TV 4S 55"
after upgrading to new firmware yerterday, the sound output becomes so weak.
before 20% sound volume was enough, now 30% still not enough.:s11:
osh6
Mi TV 4S 55"
b4 the update, the volume is 0-50, after update the volume is 0-100, if b4 volume at 20, now u have to adjust to 38-40 for same volume, actually find that this latest update more or less improved the sound, b4, the vocal is quite soft, if adjusted to audible volume, the special effect sound like explode sound will be too loud, now i find that its more balance as compared to previous firmware, eg. previously need to set to 20-25 for more audible vocal, but risk of very loud effect sound, now at 36-38 is enough for most show without too loud effect sound.
gnixer
Must power off not just press the button on the remote.
Yes, switched off at night the next day the pairing doesn't work anymore
Teo Ming Ern
Anyway as an update, I installed MeWatch and it installed fine, launched fine but crashes when trying to watch something...
ABuNeNe
my 2 years old mitv 4s 55" went kaput today, anyone knows if this can be fixed?
yusoffb01
Open up and replace the controller which connects to display cable
Tv nothing much to replace
Power board
Main board
Display controller
Display cable
Lcd panel
cruizer_ph
prices are now close to the Samsungs ($200)...
though someone posting here their Mi TV spoiled after 2 years is scary 😱
also looking at 65" Aiwa which is about just +100$ compared to the Xiaomi but has 3 year warranty
8-lane
Ic ok.. maybe u can consider getting Mi TV from Courts.. they have dunno 2 or 3 yrs official warranty IIRC..
