Samsung Galaxy Note 20 | Note 20 Ultra
rharish_21
Go to settings - about phone. The model number should be SM-N9860.
Just Sharing my experience.
HK, Taiwan and China set also the same model number SM-N9860. But only HK with CSC (TGY) works exactly the same as local sets (except no samsung pay rewards). But Taiwan and China one has the caller id display issue which is explained few pages back.
So the safest way to conclude is, check in the about phone -> software information look for the csc code.
tohchr
My HK sets had no issue with caller ID. Names will still appear.
rabbit1
lol now Sammy pushing ads on the multitask screen on N20U.. Not sure when will Singapore model be affected by this wonderful change that I am sure one or two people here will cheer on it :) !
https://www.reddit.com/r/GalaxyNote...be_a/?utm_medium=android_app&utm_source=share
earthtk
Hi guys, just wondering, if I get those SD export set, can use samsung pay and transit?
Sent from Samsung SM-N970F using GAGT
rabbit1
HK set can. Transit no screen off. Must as well use Gpay since they having instant cash back.
DaRRenLieW
Wah my heart skip a beat. I happen to saw the post here and went to lazada and see. After add to cart . $100(lazada) , $30(posb) , $10(shop coupon). I went ahead and buy @ $1381.49 ($1.49 for delivery charge) for the 8/256 white
The shop is alpha telcom . Gave up on s20fe and 8t . Left only note20 SD best replacement liao
Those who get from alpha telcom is HK set right?
Sent from HUAWEI Mate 20X using GAGT
dodongdodong
You missed another $8 voucher. Yes, it's HK set but 1month wrty only
Btw, I think it's 12/256
DigDub
Ya alpha telecom is HK set. Do note if you are on starhub, volte is not available. Apn for starhub also need to configure manually.
Zinc-Oxide
Welcome to n20u family 😃 Enjoy your SD set!
