Xiaomi TV Discussion Thread VI [consolidated]
GoodBetterBest
Hi ! Could be silly question. Pardon me.
I'm reading up on HDMI ARC. For all the diagram I've seen, they connect a HDMI device and then draw a return sound path to the device from the TV (left). Or, they draw a forward sound path (right). Like this:
So I wonder if I connect a soundbar to the TV and watch digital TV programs (where there are no other HDMI devices involved), would the sound be sent to the soundbar ?
Thanks very much !!!
shadow84
Set up the TV and quality is really not bad for $381. Got some backlight bleeding but still decent. IPS screen is vibrant enough but HDR mode is cui, had to turn it off.
matrix05
Hi Folks!
For those who already have a soundbar pair with your xiaomi tv.
Is there any latency experienced between the video played and the output of sound when using bluetooth as the connectivity?
Thanks in advance!:s12:
You connect sound bar to TV via Bluetooth?
VideoOne2
Yes the TV will send audio (via the red ARC cable) to the sound bar.
You can connect additional HDMI sources directly to the TV and the ARC will also send the audio to the sound bar.
jin4uan
After reading your post and went to check mine. Found a spot bleeding backlight at the lower part of the screen. Is it normal and just have accept it?
shadow84
This is part of IPS design iirc. Just a matter of how jialat. Besides, warranty do not cover backlight bleeding.
bigbadber
Yes to your qn.
Also, channel everything to your TV. thats why I prefer my TV to have at least 3 HDMI inputs. I connect my PC, my entertainment system (thru ARC) and 1 more perhaps TV box or game console....
so this way, everything that is played on TV will have its audio automatically played on my sound system through ARC
GoodBetterBest
Think its samsung hw-m360. Abit troublesome to connect thru optical and need to run the wire through my feature wall. Sound quality better if using optical as compare to bt?
I'm looking for a sound bar myself, so I don't know. I understand bluetooth potentially can have delays and also you need to turn it on. I'm thinking of getting Creative Stage which has HDMI Arc, and save the trouble in handling the soundbar volume and on/off.
GoodBetterBest
I wonder is anyone has set up the TV for karaoke using app ? What mic to use ? Bluetooth ?
Has anyone also set up the TV for conference ? eg Zoom ?
Can play games on the TV also ?
Thanks for any suggestions / advice.
jin4uan
Just tried optical, sound way softer as compared to BT. Guess I stick to BT then.
What do you mean by soundbar need to on/off? So far my no need to do anything to the soundbar, seems very much auto..
GoodBetterBest
oh, ok. I have 2 BT headset, one will auto-off, the other, I have to manually switch off. So once switched off, have to switch on. I guess the soundbar is always switched on ?
Good that you've tried and found the better option. :)
Wander
Not soundbar but Bluetooth headphones - no lag if directly connected to tv... but got lag if connected to a Bluetooth transmitter via headphone jack. Very slight lag, less than 0.5 seconds...
Thanks! Yep I notice mine has slight lag as well. Was worrying it may too happen to the sound bar as well. Probably gonna connect directly to the tv instead :D
giggss
Anyone has this problem?
Connect via 3.5mm headphone jack to external speaker. Sound can be outputted from the external speaker.
BUT
Once the external speaker is powered OFF, sound does not come out from TV speaker. I need to unplug the 3.5mm audio cable from behind the TV before sound will come out from TV speaker.
In short, as long as there is 3.5mm audio jack plugged into the back of the TV, the TV will always try to output audio to the external speaker (regardless the speaker is powered on or not)
GoodBetterBest
BUT
Think this is the normal behaviour of the 3.5mm audio jack. The signal is one way only. When it's plug into the TV, it will cut off the signal to the internal speaker... just like your phone.
