Just signed up to Mighty Secure. Does this mean that we can now discard the physical token?
forced to activate mighty secure as token cos physical token cannot be used after long period of unused state
They already phase out physical token. So yes.
That is the reason I activated as well - original token battery was about to give up the ghost.
Just curious if activating Mighty Secure actually deactivates the token or whether it's still valid (battery permitting).
Or what happens if one's phone dies and you get a new handset...
Once you register the mighty secure, the old token is decommissioned.
Ok, so for 100% after registering for mighty secure I can dispose of the physical token?
At dbs and uob, yes. At UOB for high risk transaction (e.g. Adding new payee) you additionally need to key your mighty secure PIN on the mobile device to approve.I still select the sms option when performing transactions on uob ib ****. All these new uob & DBS soft tokens is it same rike Stand Chart you just need to click “approve” when the prompt appears?
Ok, many thanks, will discard UOB physical token then.
Old UOB iPhone app also not needed anymore now that the new UOB Mighty app is available?
You better keep it. You never know. On internet banking, there is still option to select SMS or token.
They are not scrapping the token yet, do keep in mind there is still people not on smart phone or smart phone with correct OS version to support Mobile token.
Once the Mighty Secure has been installed on a phone the PIB login doesn't offer SMS/SecurePlus token option anymore.
Does anyone confirm the UOB SecurePlus token is 100% useless now?
On the FAQ webpage UOB only says Mighty Secure only replaces the physical token but don't specifically asks to dispose of it or that it has been deactivated.
