Xiaomi Powerbank 3 differences?
m/mink
Does anybody have these 2?
I see the difference until blur..
https://www.qoo10.sg/item/XIAOMI-XI...ANK-FAST-CHARGING/506896742?banner_no=1305330
m/mink
The version with the circle button doesn't support USB-C output, while the version with the rectangle button support USB-C output.
Both versions support USB-C or micro USB input, and USB-A output.
Posted from PCWX using HUAWEI ALP
Thank you!
rectangle button. USB-C output ..
means this type of wire? I haven't come across this for phones yet, but for macbook yes.
MLL82
m/mink
rectangle button, it takes USB-C input, means I can use my phone charger with this wire to charge the battery?
HN892
amazingone
Thank you!
MLL82
Got quite a few phones come with USB-C to USB-C cables like the latest Galaxy Note phones and Google Pixel phones.
However, you can't use the powerbank to charge Macbook as the output current is only 18W. Macbook takes in minimum 45W, which only the Powerbank 3 20000mAh (Pro) can support.
HN892
Yes, you can use this type of cable to charge the powerbank. The circle button version also can be charged with this cable.
m/mink
Thank you very much, appreciated. :D
