iPhone 12 Series
EV1L
iOS 14.3. ProRAW and Live photos cannot work together. Choose ProRAW, no Live photos, vice versa.
JayBeeLwashere
Anyone using google pay here? Have linked my paylah account but unable to make any payments. Tried unlinking and linking from both side but still the same
Tp101s
I suppose GOMO which rides on SingTel network should provide the coverage reliability that I need...and with 40GB and free caller ID (not free for M1)...this might fit my requirement.
Is the monthly plan still $25 for yours?
I took Gomo, 40GB, 200/200 free caller ID. Good enough for me. Underground and all places i went to have no issue.
ragnarok95
Senior Moderator
Senior Moderator
Mine is under Gomo so it's S$20 per month.
pantss
Hi All,
i just got my iphone 12 last week. Can i just check if your fingers/hands feel numb after playing mobile games on iphone 12? It feels like there's a electric current on the phone itself especially near the charging port. The current feels stronger if i'm using the phone when it's charging.
Is it the norm for phones nowadays? or is it just me getting paranoid?
Using iphone 12 with spigen case as well....but the numbness didn't get away.
Previously using iphone 6s but don't feel any of such issues.
use a 3 pin charger to charge instead. this issue happens for me with the macbooks, unless i use 3 pin charger
mlwang
GOMO network is prepaid network of Singtel, not the same postpaid network of Singtel. It does not support VOLTE, if u make s lot of voice call , VOLTE matters. It also does. Or dialing of number to 1900 numbers. No incoming and outgoing video calling , no mms. No international incoming and outgoing sma from Singapore.
Tp101s
Thanks for sharing GOMO limitations.
If I don’t even know what is VOLTE, sma, don’t recall using 1900 or even mms and video calling...I guess I should be alright.
Of course, if there are other sim-only plans that can overcome these features at under $30 pm...I certainly would consider :)
twosix
So many... TPG, MR and CL.
Tp101s
Precisely there are many other providers with “so many features” packed within the $30pm...mostly not required by some users like myself...and even if used also not frequent. What’s the point?
samgoh87
Anyone else facing random network lost on their iPhone 12 series regardless on 4G or 5G(4G for mine) and had to turn on and off airplane mode to get back your network? Google-Ed on related topic and apparently it’s an issue with a lot of users abroad too =(
siegeholler
had that when i first bought but seems to have stopped.
twosix
These are value added services that helps push the envelope. We will still be in stone age of no one innovate. Singtel will still charge u $100 for 10GB of 3G data. Is this what you want?
Do you even need a iphone12? 7 should suffice? A $400 Android phone also can, right? Why spend so much on a 12?
Tp101s
Understand the value-added part. I welcome VAS without compromising coverage definitely.
IP12 - because I can :)
mlwang
Singtel sim only plan now promo, $25 for 50gb Data. I had bad experience with GOMO , I am back with SingTel sim only.
ragnarok95
Senior Moderator
Senior Moderator
If you need Volte then go singtel directly is the best choice. I jump from Gomo to Grid, less than a month jump back to Gomo, still the best sim only for me over grid and M1.
ekardo
funny..if you are happy with your telco, then you shouldnt come here to look for better opinion, or to comment about the new features being useless...
what is totally useless to me is all the number games...why need so much sms or data?
any plan with >200SMS, >30GB data
unless you are playing only the number games to feel song, or you dont have fibre at home...
anyway, please stick to discussion on IP12 and not on the telco here...
Tp101s
Wow..that’s quite troublesome. Ok will take this into consideration. Thanks for sharing this experience.
