Samsung Galaxy Note 20 | Note 20 Ultra
Nero666
Lesson learned, always go for hk set even Korea set is cheaper. But I rather spend more to get rid all of the problem that Korea set had
MIVEC525
any recommended screen protector ?
SteveAu
Get from LG U+ teleco and u will have the LG logo on Samsung phone.
For me i am not a gamer. Korea set works perfectly okay for me. The speed of usage is pretty fast.
So i am very satisfy with my korea set. Most of my phone numbers are without +65 too so i have no issue of caller id.
deejay6901
got my phone updated to one ui 3.0.. very simple step actually. change the csc of ur choice(with android 11 ofc), then phone will factory reset, afterwhich do software update then its done.. im using PH firmware btw. :)
Sent from Samsung SM-N986B using GAGT
dodongdodong
Do you need to root?
cydutzyahoo
Need feedback from community whether my note 20 Ultra is having issue or not. I feel the screen is a bit greyish when compare to my note 9 very vivid screen
I have change the display setting to vivid and even toggle to the warmest tone. But when I put side by side with note 9 to compare, the picture is very dull and greyish. Skin color of a person is not as warm as note 9
Should I get replacement?
Glariel
Just take your set compare with display set
