Lesson learned, always go for hk set even Korea set is cheaper. But I rather spend more to get rid all of the problem that Korea set had
How to get LG in Samsung?
Can HK set connect to local 5g?
Original film or WS glass is the best in my opinion.any recommended screen protector ?
Posted from PCWX using SM-N986B
Original film is the best ... Coming from both WSD and hydrogel film.original film is not tempered glass, guess wont sustain if drop?
Sent from Samsung SM-N9860 using GAGT
Yup, preinstalled to all new phones... Be it local or imported.thanks. all phones comes with it? not sure is mine installed... local set
Get from LG U+ teleco and u will have the LG logo on Samsung phone.
got my phone updated to one ui 3.0.. very simple step actually. change the csc of ur choice(with android 11 ofc), then phone will factory reset, afterwhich do software update then its done.. im using PH firmware btw.
Sent from Samsung SM-N986B using GAGT
no root needed
Just take your set compare with display setNeed feedback from community whether my note 20 Ultra is having issue or not. I feel the screen is a bit greyish when compare to my note 9 very vivid screen
I have change the display setting to vivid and even toggle to the warmest tone. But when I put side by side with note 9 to compare, the picture is very dull and greyish. Skin color of a person is not as warm as note 9
Should I get replacement?
