Mini pc?
watzup_ken
Get this.
https://www.aftershockpc.com/welcome/Productinner/vision-mini
Basically the A300 that the folks here have recommended. But in this case, you don't have to get involved with SLS. They will fix it for you and troubleshoot for you if anything goes wrong. I recommend going for the Ryzen 5 3400G if you can stretch your budget. Avoid the Intel and Ryzen 3 options because they don't seem to be very good in value.
AlchemistJ19
Seems like after adding windows 10. The prices will creep to around 400-500 bucks. Unless u run on Linux... Hmmmm
cesc88
Get this.
Thanks. I did a search online by comparing RX Vega 11 (which I understand is Ryzen 5 3400G's igpu) with GTX 1650 (ZOTAC GTX 1650 SUPER OC 4GB is the cheapest gpu in Aftershock). (https://www.notebookcheck.net/Vega-11-vs-GeForce-GTX-1650-Desktop_8470_9850.247598.0.html) & (https://technical.city/en/video/Radeon-RX-Vega-11-vs-GeForce-GTX-1650). Noted from the first link that "modern and demanding games will only be playable in lowest settings and the APU is mostly intended for lower demanding games like Overwatch, Dota 2" and the second link seem to suggest GTX 1650 outperformed RX Vega 11.
I am using this as a second PC in my room for surfing net, watching YouTube, and playing Dota 2 (currently the only game I play). Am I right to say RX Vega 11 is sufficient to meet my needs of playing Dota 2 (since surfing net and youtube can be done easily)?
Actually, is getting a mini pc just for the small form factor? Is it much more economical to get a desktop pc?
sorry if my questions are noob. still new to this
gld998
Actual what is your question again?:s8:
NightRaven49
of course dgpu will most likely beat igpu. 1650super is a pretty decent gpu at that, delivering rx570 performance. but igpu will still handle general use like web surfing and light gaming, and means u dont have to buy dgpu (which in the case of the 1650super costs at least $250) so can save some money. the vega 11 igpu is pretty much the best igpu u can get right now, trashing intel's offerings.
wanting mini pcs are usually a matter of preference. some just not enough space, others want to cram as many powerful parts into the smallest space possible. i dont really think whether it is economical or not really matters, since more often that not it is your budget that determines what u get. it is worth noting that parts for itx builds usually come at a premium.
gld998
:s13:premium is just a perception. :D
bleachberu
I looked at the aftershock Vision model. It fits the SFF which I like but it does not have a separate graphics card or the ability to add one on later?
Are there more such models out there?
NightRaven49
u will most likely need to build ur own itx rig.
the vision model is just basically an asrock deskmini (which is purpose built for cpus with igpus) with all the parts already installed.
Lenovo ThinkCentre M90n Nano seems to be pretty good. And it is said to be availbe in US for around US$400 for the Core i5 version. But it seems to be too expensive in Singapore, SG$838.73 for Core i5-8265U 8GB 128GB version.
https://www.lenovo.com/sg/en/deskto...-series-tiny/ThinkCentre-M90n-1/p/11TC1MNM93N
https://www.lenovo.com/sg/en/deskto...tiny/ThinkCentre-M75q-Gen-2/p/11JJCTO1WWENSG0
SG$934.20 with the following customization of Lenovo M75q Gen 2. This seems to be a much better buy than the M90n Nano in terms of specification. But it is of course bigger.
Processor : AMD Ryzen 3 Pro 4350GE Processor(2MB Cache, Max Boost up to 4.00GHz)
Operating System : Windows 10 Home 64
Operating System Language : Windows 10 Home 64 English
Form Factor : Tiny Renoir
Memory : 16GB DDR4 3200MHz SoDIMM
Video Adapter : Integrated Graphics
First Hard Drive : 500GB Hard Drive, 7200RPM, 2.5",7mm
Second Hard Drive : 512GB Solid State Drive, M.2 2280, NVMe, Opal, TLC
Networking : Integrated Gigabit Ethernet Port
WiFi Wireless LAN Adapters : Intel Wi-Fi 6 AX200 2x2AX, Bluetooth Version 5.0
USB-C Port : USB-C Port
Dust Shield : Dust Shield for Tiny
Power Adapter : 65W adapter
Speakers : Internal Speaker
Publications Pack : Publication-English
Warranty : 1 Year On-site
gregory_choo
recently I bought a set of Lenovo M93p with
- Intel Core i5-4570T 4thGen 2.9Ghz
- 8GB RAM
- 500HD
- Win 10 Pro and Ms office Pre loaded.
- DVD RAM is included.
$250 only, brand new from lazada.
- 8GB RAM
- 500HD
Looks good, upgrade the 500GB HDD to an SSD and this should be fine for me to run Windows/Linux.
Please share the Lazada link, thanks.
yusoffb01
- 8GB RAM
- 500HD
thats a 7 year old used pc
