Mini pc?
thats a 7 year old used pc
I think Greg mentioned brand new set.
Yes the CPU is 7 years old but it may still be good enough to run Windows 10 and Linux with the Core i5-4570T CPU and 8GB DDR3 RAM. Main thing to upgrade is only to replace the 500GB HDD with a 256GB or 512GB SATA SSD.
watzup_ken
I looked at the aftershock Vision model. It fits the SFF which I like but it does not have a separate graphics card or the ability to add one on later?
Are there more such models out there?
I agree that you will need to DIY an ITX rig if you want to have a dedicated GPU. Most of these mini PCs don't have the ability to add on cards because of space constraints. They are generally designed to be used with integrated graphics.
gregory_choo
I bought it in Sep. I think I bought one of the last few brand new sets. My order link is not valid anymore.
At the moment, many sellers on lazada selling refurbished sets.
you may want your luck to search new sets.
kimsix
https://www.lenovo.com/sg/en/deskto...tiny/ThinkCentre-M75q-Gen-2/p/11JJCTO1WWENSG0
SG$934.20 with the following customization of Lenovo M75q Gen 2. This seems to be a much better buy than the M90n Nano in terms of specification. But it is of course bigger.
Processor : AMD Ryzen 3 Pro 4350GE Processor(2MB Cache, Max Boost up to 4.00GHz)
Operating System : Windows 10 Home 64
Operating System Language : Windows 10 Home 64 English
Form Factor : Tiny Renoir
Memory : 16GB DDR4 3200MHz SoDIMM
Video Adapter : Integrated Graphics
First Hard Drive : 500GB Hard Drive, 7200RPM, 2.5",7mm
Second Hard Drive : 512GB Solid State Drive, M.2 2280, NVMe, Opal, TLC
Networking : Integrated Gigabit Ethernet Port
WiFi Wireless LAN Adapters : Intel Wi-Fi 6 AX200 2x2AX, Bluetooth Version 5.0
USB-C Port : USB-C Port
Dust Shield : Dust Shield for Tiny
Power Adapter : 65W adapter
Speakers : Internal Speaker
Publications Pack : Publication-English
Warranty : 1 Year On-site
use promo code HZCNSALE :o
