Which Wifi6 / BT5.0 card?
TechNuB
i intended to get the intel ax200 but was informed that it wont fit into my
B550M steel legend / Forge M combo..
any other alternatives? budget under 50 thx
CopySeeSewDye
Any reason why it wouldn't work? I'm also considering the same option with the b550m steel legend using this m.2 wifi card and the wifi antenna cutout at the io shield. I thought it has a dedicated m.2 key E slot for wifi card. Haven't tried it yet tho...
https://www.amazon.sg/Wi-Fi-Desktop-AX200-2230-vPro%C2%AE/dp/B085M7VPDP
yusoffb01
get ax210 instead. $25 at lazada and has triple band
TechNuB
why wouldnt it fit? as long as have m2 b key slot it will fit.
https://www.asrock.com/mb/AMD/B550M Steel Legend/index.asp#Specification
https://www.amazon.sg/Wi-Fi-Desktop-AX200-2230-vPro®/dp/B085M7VPDP
i was recommended the ax200 card from a fella forumer, but when i went down to this shop in sls to buy my pc , he said it wont fit. so i didnt buy lol..
any 1 using similar combinations can verify? or is there some buying guides from hwz?
What exactly is this product called? a wireless adapter or wireless network card? or are they the same??
NightRaven49
u just blindly believe what he say ah?
just get those wifi card to pcie adapters and stick it into the lower x1 (or x16 if using thicker than 2 slot gpu) pcie slot.
CopySeeSewDye
Im guessing this is just it. He tried with a pcie wifi card instead of the m.2 one and i guess ur gpu is too thick and he probably didnt try the x16 slot... This video is for the b460m steel legend but installation should be the similar for b550m. Ask for a m.2 (key E) wifi kit instead of a pcie one. The only trouble would be routing the antenna cables haha.
https://youtu.be/Ai99pG4jnDo
TechNuB
yea i had my doubts but i didnt wana risk it since i could verify here first before ordering 1 online...
86technie
are those antennae necessary?
since some 1 mentioned AX210, i m thinking of this from webe.
https://shopee.sg/-SG-Seller-Intel-...10NGW-(AX200-AX200NGW)-i.266454904.5460356109
That is for notebook but not desktop.
Recommend Asus PCE-AC55BT, Wifi and BT but over your budget
as this cost around $80.
This card will be more reliable than buying OEM M.2 card than find a PCI-E adapter which may not work properly.
https://www.asus.com/sg/Networking/PCE-AC55BT/
flame2000
You just need to make sure the Wifi Card is "M.2 key E" so it fits into the WiFi card slot on the motherboard.
Then you need run 2 small cable from the card to the PCI slot for the antenna, something like the one below.
If too lazy to do the above, you can just get the PCIe Wireless Wifi Adapter that plug directly into the PCIe slot for convenient sake.:D
NightRaven49
TanKianW
Go search on taobao and buy one. Remember to buy the wiring and antennae if it does not come with one. Just chat with the seller to verify it could fit.
I find it perfectly fine buying from OEMs, so long the type of connector (Min-PCIE or M2) is correct. There is also a lot of "branded" cards using these OEMs. I have bought quite a few AC cards in the past to breath new life to old motherboards and laptops still using G.
shadow84
Is this compatible with AMD based motherboards ?
Product description is Compatible With Intel based Laptop or Desktop (if you have a PCIe convertor/adapter).
If using with pcie adaptor, will be compatible with either platforms.
86technie
If use with PCE convertor/adapter should work.
Think it is not whether Intel or AMD but whether the motherboard
supports M.2 Wifi card or not.
There are motherboard with build in Wifi which are using M.2 Wifi cards.
It's rare these day where there is a motherboard with a M.2 Wifi card slot since
majority these days most M.2 slots are for storage but not Wifi.
I recall there was one but that is a really old and out of date motherboard that supports M.2 Wifi.
cscs3
If not in hurry and current already has wifi to use. Wait for Wi-Fi 6+ or the so call WiFi6e. Is coming soon.
CopySeeSewDye
Actually alot of current asrock boards has dedicated m.2 key e slot for wifi cards in addition to the regular 2 x m.2 slots for ssds. Theres even 1 asus mobo (think its the non wifi tuf b550m) that has m.2 key e for wifi haha (although u can just buy the wifi variant).
