Sony xperia 1 II
omelet
I have done this, disabling and making a call, then re-enabling and making a call. Everytime the icon will change from LTE+ to H+ when the call is made :sad:
Mine starhub also working, but dunno how to help u...
As you can see the VoLTE option means it is provisioned just not working properly...usually if not supported you won't even see this option inside settings.
Maybe can make sure all your play store app are up to date, go to settings -> software update make sure apps also up to date. Maybe is one of the carrier update/support update that fixed it?
Also try going to network & internet and tap internet settings to redownload...try try
eciloP
So far at times there will be no data connection for my phone. I am on Starhub and will need to restart the phone. Anyone experiencing this?
kimsix
new firmware give dec security update.
geekbench 5 results still super low than android 10 (900 vs 700, 3200 vs 1800). this is after a factory reset. :o
night standby seems good, 2% over 9 hours with same daily settings.
not for me
but some pixel users complain new updates have this
https://forums.hardwarezone.com.sg/...fficial]-google-pixel-4-4-xl-6026606-265.html
eciloP
kimsix
monthly updates first to get, major updates last to get T_T
it is good for once an SG phone get fast update besides apple or google. :o
but android 11 severly degrade performance (in benchmarks), maybe sony HK is holding back?
Hi, any wireless charging for Sony 1ii?
yes have. 1ii is quite a complete phone, except 5G. :o
Adam80
Is it me or does "normal camera" is hard to focus on text sometimes?
I need it for work related like wording on box
Sent from Sony XQ-AT52 using GAGT
stone1978
Oh no 5G ah? But I saw in Lazada some stated 5G but Sony store also no 5G. Kinda confuse...
Edited: just saw this in Sony website stated 5G
Qualcomm® Snapdragon™ 865 5G Mobile Platform21
kimsix
yalor no 5G because sony sg never work with telcos for certification.
the hardware is there. :o
but no loss imo, save battery life and 4G still fast enough outside.
stone1978
That's sucks! Seems like all sg Telco abandoned Sony.
Toader
Yes quite a lot of glitches for snapdragon 865 version. Thats why both 1II and 5II delay release I believe.
darkmatt
I have a feeling the 5G isnt supported.. YET..
But once it becomes mainstream, as long as your phone has the LTE band, it can support it. For now its "on trial" i guess..
rssd21
Probably. The same sh*t happened during the introduction of 4G/LTE networks when people are confused which phones are supported by the local telcos.
rssd21
Aside from higher consumption, 5G network is also not stable yet and the present coverage is still lacking.
