AMD Ryzen Notebook discussion | Intel or AMD for notebook? AMD Excellent CPU+GPU performance, sharing concurrent models reviews.
lionheart80
can anyone help advise which model will be more worth and with better cooling
Yoga Slim 7 Pro 14ARH5
Part Number: 82LACTO1WW
Processor : AMD Ryzen 7 4800H Processor (2.90GHz, Max Boost up to 4.20GHz, 8 Cores, 8MB Cache)
Operating System : Windows 10 Home 64
Operating System Language : Windows 10 Home 64 Traditional Chinese/Simplified Chinese/English
Microsoft Productivity Software : Microsoft Office Trial
Memory : 8GB DDR4 3200MHz Onboard
Solid State Drive : 512GB Solid State Drive, M.2 2280, PCIe-NVMe, TLC
Display : 14.0'' 2.2K(2240x1400) IPS AntiGlare 300nits 100%sRGB Non-Touch
Graphic Card : Integrated Graphics
Camera : IR&HD Camera No Mic
Microphone : Array Microphone
Color : Slate Grey
Keyboard : Backlit Keyboard Slate Grey English
Wireless : Wi-Fi 6 2x2 AX, Bluetooth Version 5.0 or above
Surface Treatment : Anodizing Sandblasting
Palmrest : AL
Battery : 4 Cell Li-Polymer Internal Battery, 61Wh
Power Cord : 95W AC Adapter Black (3pin)-UK (USB Type C)
Language Pack : Publication-English/Simplified Chinese/Traditional Chinese
Warranty : 1 Year Carry-in
Price : $1234.25
Yoga Slim 7 14ARE05
Part Number: 82A2CTO1WW
Processor : AMD Ryzen 5 4600U Processor (2.10GHz, Max Boost up to 4.00GHz, 6 Cores, 8MB Cache)
Memory : 8GB LPDDR4X 4266MHz Onboard
Hard Drive : 512GB Solid State Drive, M.2 2280, PCIe-NVMe, TLC
Display : 14.0" FHD (1920x1080), IPS, Anti-glare, 300nits, Non-touch
Color : Slate Grey
Fingerprint Reader : Fingerprint Reader
Keyboard : Backlit Keyboard Grey English
Palmrest : AL
Battery : 4 Cell Li-Polymer Battery, 60.7Wh
Power Cord : 65W AC Adapter Slim (3pin)-UK (USB Type C)
Package Box : Gift Box
Price : $1234.25
both prices inclusive of 2 yrs premium care with accidental damage protection and sealed battery
SpecialKeyboardService
All the model like 8gb ram.
8gb ram very fast use finish.
Consider getting amd t14 400nit version.
Can get max 16gb ram sodlered
bumdssa
NEWYEAR21 is back (seems like it disappeared during the daytime) on Lenovo website. Dunno whether use of this can stack with Shopback
Below for less than $1100
ThinkPad T14s
Part Number: 20UHS01300
Processor: AMD Ryzen 5 PRO 4650U Processor ( 2.10GHz 3MB )
Operating System: Windows 10 Home 64
Display Type: 14.0"FHD, IPS, AntiGlare, LED Backlight, Narrow, 45%CG, Non-Touch 1920x1080
Memory: 16.0GB DDR4-3200 DDR4 SDRAM Onboard 3200MHz
Storage: 512GB SSD PCIe NVMe
Warranty: Three year Carry-in
AC Adapter: 65W
Graphics: AMD Radeon Graphics
Battery: 3 Cell Li-Polymer
Bluetooth: Bluetooth Version 5.0
Camera: RGB 720p HD Camera & MIC, with ThinkShutter
Fingerprint Reader: Fingerprint Reader
Keyboard: 6-row Backlit English (US)
Wireless: Intel Wi-Fi 6 AX200 2x2 ax
Is the T series better than the E series?
creative_vitamin
ThinkPad T14s
AC Adapter: 65W
Thanks! Any thing for touch screen too?
firesong
Deluxe Member
Definition of better? Price wise, the E series is better. L and E series are budget versions of the T with more compromises and fewer configuration options. Definitely plastic chassis.
Build quality wise, the T is better. The T series is their traditional series inherited from IBM before they branched out to other sub-brands, so now the X1 series tops the T-s series, with the T (non-s) having less premium materials and are slightly heavier. T-s are thinner and lighter with a magnesium alloy/carbon-fibre chassis; the T have glass fibre PPS with rubber coating for the chassis.
firesong
Deluxe Member
An interesting resolution to Intel’s claim about its processors being better than Ryzen 4000.
https://www.extremetech.com/extreme...-huge-ryzen-4000-performance-drops-on-battery
We do not consider Intel to have proved its thesis — namely, that we should regard “up to 48 percent slower” as a reasonable evaluation of AMD laptop performance or that performance testing on AC power is so unimportant as to even consider discarding it, under any circumstances whatsoever. By sourcing 80 percent of its AMD systems from Lenovo, Intel guaranteed that its Intel-versus-AMD turbo behavior comparison would effectively be an Intel-versus-Lenovo comparison, with a single HP system tossed in. This limited comparison does not support the claim that Intel’s findings negate AMD’s product stack, and it does not validate the sweeping changes Intel believes should be made to product testing.
Somehow, it had instead exposed Lenovo for the poorer performance decisions vs power efficiency. Something for us Lenovo users to keep in mind.
Henabi
Shingoz
Does anyone has word on when the ryzen 5000 series will be launched by lenovo in Singapore?
firesong
Deluxe Member
Reportedly shipping from March according to some international reports, but dependent on whether Lenovo Singapore would release those models. Also, bottleneck of chip supplies at TSMC end due to an explosion in demand will slow down release for a while.
Shingoz
This TSMC, is it listed? Go buy the stocks!
bumdssa
Thanks for the detailed info.
Looking for 15inch for work purposes and not gonna really bring it around. But T15 is too expensive.
firesong
Deluxe Member
If mobility is secondary, consider the Legion. It should exceed your expectations.
flowerpalms
Hold your horses for the new models
Posted from PCWX using A simple life, not a simple thing 🙏🏻
firesong
Deluxe Member
Posted from PCWX using A simple life, not a simple thing ðŸ™￾ðŸ￾»
Why buy? Wait for Zen 100. Will be better than what's only the third generation :s22:
Honest advice, if you need it, buy it. If you don't need it, don't buy. Those who need it will know if they need it. There is no need to repeatedly dissuade users - their money, their decision.
flowerpalms
If you are still interested of the older model and see no point to wait for delivery since ryzen 5000 and rtx 3000 series coming.
