Xiaomi 34" ultrawide monitor
cantofish
almost bought from them, heng saw this thread. got other sellers to recommend? okay to pay a small premium
CeSaRiO
I personally will buy from Xiaomi SG and pay the premium over Prism+.
My set was shipped directly from China during last year 6.6 sales and so far no issues till date.
DevilishZ
See you heng or suay.
Not sure if xiaomi sg does 1 for 1 either. But the premium in price is definitely there. but much longer warranty if I recall correctly. So is like paying for insurance.
If heng like majority of us , no issues, if suay then see if you willing to accept repaired set.
cantofish
Ok i've done some research, for those are in the same boat as me - 34in ultrawide, QHD, 144hz budget below $800
AOC CU34G2X at $799, VA Panel
Gigabyte G34WQC at $699, VA Panel also
allanzzz
Got to evaluate the risk yourself. Got mine at $400 I think from shopee which I don't even remember if it is from mini helper or others.
Luckily no issue and monitor usually don't spoil that easily so is ok for me.
$600 plus too exp for me.
Tuakong
The vertical blue line across the screen
wongminmin
is common to have defects....is really about luck
urs is eu or ru or cn set?
ur last hope is on qoo10.....
alternatively u send in for rma and buy another set. then when rma return, u sell it away.
Tuakong
It came with EU plug and minihelpers provided a 3pin plug
Yes...see outcome of Q10 followup with the seller. They told me that it will take a week for them to get back to me
I am considering getting the LG IPS monitor this time
hyperfuse
i got mine from minihelpers in qoo10 with coupons and some credit card promo..so its about $380.
Item came perfectly well. takes 2 days to deliver only. No dead pixels and its really a good and cheap ultrawide.
really see luck. i guess if u kena a set with problems, their warranty service suck. But thats expected for the lower price.
rife
can share how u managed to get such a huge discount please
Tuakong
Just a quick update that Q10 came back and said no 1-2-1 replacement as my monitor had defects on the 8th day. If within 7 days, then can replace.
Delivered on Jan 18; defect on Jan 25 (8th day). So, have to wait for service
Anyway, I bought new monitor already. Will give the xiaomi to my son.
Anyway, CASE asked me if I wanna pursue......
Just suay, thats all
katty91
can ur son get used to a monitor with a long line coming down..
I’ll just sell it off cheap n not be reminded - very unacceptable
Tuakong
I mean wait for them to repair the monitor then give my son
Next time will be more careful...must ask seller T&C for 1-2-1 replacement
