- Sep 16, 2018
Issues related to pfSense 2.5 -- not affecting me though as I am only using the basic features. But for consumer VPN (PIA, Nord, etc) users you may need to take note.
pfsense is a firewall so if I put my openwrt router behind it (not in AP mode), will this setup work? Is this more secure or overkill or lead to more problems?
Thinking of playing with pfsense if it is more secure than openwrt
Thanks all for yr comments. Best that I just learn pfsense on standalone basis for now since I have a spare old pc. Just have to dig out another NIC for now
Took the plunge.....
Installed ESXI, Synology 918+ img and going to explore with Openwrt next....
Yes from taobao .From taobao? Is this available from qoo10/shopee/lazada?
Thanks. Saw this on TB too.Yes from taobao .
I believe you should be able to get variations from shopee/lazada but at a much higher price.
Didn't find any fanless J4105 and better (J4125 or J5005) using intel nics on shopee/lazada. Most use realtek nics. Don't need 4nics, two will be all i need.
Need to get in a hurry as VPN endpoint device just uplorry.
How long did yours take to arrive after ordering on TB
Yes, mine is 4 x Intel i211 Nics. In fact I dont need 4 ports, but since I install ESXI and OpenWrt , my port 1 is dedicated for ESXI management Lan port.
My other 3 lan ports are passthru to my OpenWRT. The 2nd and 3rd ports are meant for Dual Wan (i intend to get another fiber connections soon) and allow me to do load balance or dedicated SSR connections. Port 4 is reserved in case I need to use it for something like NAS device
Dear all,
what is the recommended spec of if I want to do dual Wan or triple Wan out to a single lan port.
