Aircon will start to leak water after 30 mins to 1 hr, unit already 14 years old. Possible to self fix? Will it resolve by itself in future? Thanks!
Go buy wet/dry vacuum cleaner and suck the outlet of your condensate drain.
Most likely insai all the jelly.
Dry vacuum cleaner no dangerous?. I did it once and inside the vacuum bag compartment flooding.
sometimes not choked pipe..the thick dust coat at the filters will cause leaks too.
Sent from my friend's phone using GAGT
Wet/dry vacuum means those that can do both wet and dry.
Do not use dry, ie normal vacuum to suck water.
Anyway this type 99% easy case. Pipe choke only. Can suck out all the jelly one.
