Samsung Galaxy Tab A7 (2020)
stupidog
anyone got good tempered glass to intro ? i need very good oleophobic TG
shopee ones apply liao alot of fingerprint sia
i use it to read manga, end of the day the whole screen smudged with prints and grime lol
kelvinti
Got firmware update that includes March Security. :)
Mine is an export set from Samsung Malaysia! :)
bigbadber
I just buy from AliExpress. Cheap and good.
And I regularly clean it with alcohol wipes. Or use a bottle of isopropyl alcohol and tissue paper. Same thing for my phone.
Isopropyl alcohol u can buy from those ABC Value shops. Before Covid it was $2.95. Now selling at $4.95. Its a 500ml bottle, can last u a long time
stupidog
OIC. Thanks. but i got one tin of 18L IPA in my store. haha
bigbadber
Wow where to buy such a big quantity and how much does it cost?
Isit 70%?
Very useful to clean things at home, like things with rubber like computer mouse, keyboard, places where fingers frequently touch like light switches, remote control, or if ur wall is lightly stained, can wipe it off...
Or i also spray on areas to clean, like dusty spots. Or I spray on tissue then wipe the areas I wanna clean. Cos it dries fast. If use water, then the water might spoil those wooden areas
stupidog
Isit 70%?
https://www.horme.com.sg/product.aspx?id=3387
mine is 99.8% , if need 70% can mix with water.
i use 99.8% to clean/wash PCB. 70% got water so better not to use it on PCB
i mixed it to 70% to clean KB, mouse and hamfone. 99% too strong to use on some plastics/wood. Especially our specs & furniture
chromehead
alcohol can't anyhow spray on wood with finishing applied, some can get dissolved
can mess up some plastics too
i always wonder what is used for oleo coating, use strong solvents may be able to strip it eventually
bigbadber
oohhhh okie thanks. will take note.
damn. uncle so not used to the new format of HWZ
Dorkable
I find the street pricing for the A7 64GB LTE rather bad. It is priced the same, if not higher than a S6 Lite 64GB LTE (street price).
Teo Ming Ern
I just checked GSMArena... they're essentially identical except for slight difference in dimensions, weight and A7 used SD662 and S6 Lite uses Exynos 9611... so pricing probably reflects similarity in specs?
Dorkable
Well, the thing is, S6 Lite LTE at that same price, has 1GB ram (4GB) more than the A7. Additionally, S6 Lite supports Dex and comes with SPen.
freshvibes
Ha, yeah, that was exactly what I did. Was intending to get myself a Tab A7, but ended up buying a Tab S6 Lite 128GB LTE instead.
How is the Tab S6 Lite so far?
Is it really a better buy as compared to the Tab A7?
