Suggestions to improve search functionality
harbinger255
Can we have the default sorting of search results be by date instead of by relevance?
I realized the relevance sort is quite crappy anyway and results are all over in terms of date. Right now only work around is to go into advance search and change the option - would be good too if there is an option to sort results by xxx in the results page but I think most here will be better served with date/time as default.
Dragon
Administrator
The tech team is still refining the Search function. Meanwhile, yes please use the Advance search if you do not wish the results to be relevance sorted by default. 🧑‍💻
Tiraimisu
The jump to other forum thread is locked so dun mind TS I post here.
Actually I find by bookmarking the sub forum is even faster to access the sub forum than scrolling through the drop-down list as the list are way too long:s22:. I propose to hide the sub forum with a + sign. E.g. Mobile + so when u click that + it will list out all content under mobile. Same for travel.
I find the list too long to scroll when I just want to go homeseeker...the drop-down list has room for improvement.:o
@Intrinion
Intrinion
Senior Moderator
Senior Moderator
@Intrinion
Something similar to this :) ?
razorlala
Just some feedback on the ux..
The search button is the action button.. Abit strange that its not the first button when aligned left/right.
Think the search and advanced search shuld swap position. And search button can use the same css as post reply button
Dragon
Administrator
Thanks! Your suggestion is duly noted. (y)
