Using Kaiser+ grill lock. Ordered M1192 from qoo10, they gave me m1191 with metal body for the body facing inside. Supposedly free upgrade. Is meta body on inside really so important?I am also looking at Kaiser for metal gate. Which version are you looking at and which are the metal ones..?
for metal gate, I find that there isn’t many Brand.
anyone has any recommendations.
Is Igloohome work with home kit? Metal Gate and Door.Igloohome just release their metal gate lock. Would definitely have considered this if it had fingerprint unlock
https://www.igloohome.co/products/rim-lock
No it doesnt. That's one of the reasons I didnt get it.Is Igloohome work with home kit? Metal Gate and Door.
I use Schlage 510f for main gate - very solid, can use PIN, fingerprint, FOB,RFID card. Recommended.Are there any digital locks that are suitable for outdoor gate? TIA.
Thanks TeamUSA and XiaoFu99. I presume the locks are weather proof to withstand the rain and shine as well?
Thanks! NotedNot too sure about that. I have yet to see digital lock (excluding padlock) that are IP65 certified to withstand rain.
Bro, are u sure the 5100k have the Bluetooth to wifi module? If yes, pls kindly give me the link to where I can purchase this. I own both the 9200 and 5100k. Before buying, the sales person told me that these locks will in future have this capability. After waiting 1 year for the delivery of the 5100k,I was told that both locks will not have this function......I'm also looking for one. Currently, shortlisted Philips Easykey 5100K. Retail price is going for $599 (inclusive of installation).
What attracts me most is the ability to use mechanical key in the event of failure (on top of card, pin, app and fingerprint). And also, it seems to be the only brand that offers 3 years warranty (parts + labour).
And in the event of no/low battery, instead of hunting for a 9V battery to jump start, it can be charge via an external powerbank with a micro USB cable.
Outlook wise looks pretty sleek and it does comes with a remote to unlock as well. It also support an optional bluetooth-to-WiFi gateway @ $120 which I assumed can be used to unlock/lock remotely.
Now I'm looking for a gate to change as well.
Bro, the front of the lock looks sleek and slim. But the back of the lock is not. I think you will be disappointed. Best to go for Yale lock if you want wifi unlocking and a lock that is able to lock back into your original gate lock slot.Anybody know where can I get a bluetooth-to-WiFi gateway for Philips Easykey 5100K ?
Intend to use Easykey 5100k for the metal gate.
Thanks
I am using the Kaiser+ for my gate. Quite ok. Can use fingerprint, rfid, password and app to unlock. Personally I think don’t really need gate lock la. Cheap one will do or maybe don’t even need. Yale very exYea, likely got water leak before hence the battery drain.
Apparent Kaiser+ for gate got a metal version. Tempting
For HDB or condos/apartment with limited security/access controls, i think still need a gate lock. And to me its strange to have a digital lock for main door but manual lock for gate, which kinda defeats the purpose of not having to bring/usekeys in the first place. But yes, I do have friends who don't even have a gate even in HDB so it depends on what you are comfortable with .I am using the Kaiser+ for my gate. Quite ok. Can use fingerprint, rfid, password and app to unlock. Personally I think don’t really need gate lock la. Cheap one will do or maybe don’t even need. Yale very ex
