Mapletree Industrial Trust *Official* (SGX: ME8U)
Nofear40
Just checked my CDP account on line. The rights issues are there in my account. Last day of application is 11 June right?
Dteg
First time doing rights issue with a custodian (Tiger) rather than CDP.
Initially was a bit worried but relieved now that I got the notification and things are proceeding the expected way
Opps-gal
Anyone tried apply rights with paynow? Refund can go paynow register with mobile phone?
subprimelive
when you are issued with the rights (when you check cdp), what if you don't pay for it at ATM ? does it mean that they will take back after the closing period?
demongod
anybody know for interactive brokers how does it work? do they auto apply for you, because i seem to see it in my portfolio
TehSi99
I only have peanuts shares and will only eligible for 300 shares. Think going to give it a miss and put my money elsewhere.
Unless can get excess 700 shares to make it 1000.
Paul Lee
how to pay with paynow? from atm?
The instruction on how to use PayNow will be included in the booklet that will be send to you,
You can also read it >> HERE
Basically, the instruction is to use your banking app and scan the QR Code on the form that you will receive.
I think the first thing you need to do is to change the PayNow limit on your account if you have not done so. The current limit should be $5K if you have not changed it. If you are planning to buy more than 2,000 units, then you will need to change the limit first or the transfer will fail.
foo9883
went to ATM and try try and saw these options:
Rights subscribed:
Rights in excess subscribed:
means what? Right subscribed means what you're allocated as existing shareholder?
then in excess means whatever excess you wanna buy?
PDA_lover
Rights subscribed:
Correct. Most banks will ask for quantity we are allocated vs excess that we want to subscribe.
PDA_lover
how much excess is everyone planning to apply? I am thinking of applying about 1000 extra.
Opps-gal
I think the first time you need to do is to change the PayNow limit on your account if you have not done so. The current limit should be $5K if you have not changed it. If you are planning to buy more than 2000 units, then you will need to change the limit first or the transfer will fail.
A dumb question- what it mean refund excess amount to DSC bank account?
