Xiaomi Mi 10T | Mi 10T Pro
kediraksith
If govt remove QR then i LLST... but QR is still a valid way of entry.
Now is the TT guy holding up the queue by insisting to check my phone for fake TT QR checkin...
My fault? I never wanted use scanner one but the guy insisted....
Also, this only happens at my office entry.... that siao on kia. No other place do this.
joesph
I just got
Read HWZ Forum Rules!
Oinkize
Someone recommended this from F3 thread. Not sure if it works.
Ok guys, i think i found a solution for the Trace Together app to work at the scanners.
1. Turn on Developer Mode.
2. Go to Additional Settings then Developer Options
3. Enable Gabeldorsche (its under Networking)
Kopi_si
The setting reset to disable after phone reboot.
Jun Jun
Is urs local set? Which telco u got it from? My one from m1 till now still on 12.1.3
Jun Jun
Its like when i try to focus on something the edge gets blurry or the pictures turns out like a bad painting. Unfortunately hardwarezone I can't upload pics.
Oinkize
Icic. I did not notice that for the pictures that i took though.
allanzzz
Did not work for me
