What the changes?New update out for BT model
A new update is coming
Originally I used a 3G enabled gear S3 frontier for exercising. Covers music, exercise tracking and Samsung pay if needed. All without a phone.What are the consideration points to decide on whether is worth it to get the Lte version or just Bluetooth will do?
Not worthJust an update for those eyeing the Korean GW4 from Qoo10. I bought a the BT 44mm set for S$301 after applying all the vouchers I could find.
Shipping took about 2 weeks. Except Samsung Pay, all the rest of the functions are available, including Blood Pressure, ECG, body composition etc. Since I don't use Samsung Pay anymore, it doesn't affect me.
Seller has a 1 year warranty which means anything wrong, need to send back to Korea. Local Samsung won't deal with you. So it's up to you whether you want to risk non local warranty to save money.
I have just received this update; now downloading![]()
Able to share you guys battery performance. I'm getting almost 40-44hrs for 44mm BT on normal days without workout trackings. AOD off. Feel it's quite poor.
Did you try Google pay on the watch? I also bought from Korean qoo10 seller. Google pay can be set up normally but doesn't seem to work when I tap it at pay wave readers or on the bus/mrt.Just an update for those eyeing the Korean GW4 from Qoo10. I bought a the BT 44mm set for S$301 after applying all the vouchers I could find.
Yup, Google pay works. But so far I've only tried them at shops like 7-11 and NTUC. Haven't tried bus/mrt. Assigned it to launch on double press home button.Did you try Google pay on the watch? I also bought from Korean qoo10 seller. Google pay can be set up normally but doesn't seem to work when I tap it at pay wave readers or on the bus/mrt.
