- Sep 16, 2018
New HDB BTO flat is easier than the older HDB flat in terms of planning the home network.
1) They have LAN ports in the rooms. So worse case just add more APs or cheaper dual band Mesh with Ethernet backhaul.
2) The wall is not blocking wifi signals as badly as the older flats.
More discussions for BTO Flats here.
https://forums.hardwarezone.com.sg/...-you-connect-your-home-fiber-network.4173602/
What about older HDB flats without LAN ports in the rooms?
Summary
1) All in all, the best is still to lay out Ethernet cables to the rooms (living room and the bed rooms). It may not be necessary to have LAN ports in every room, rather selected location may be good enough. Some people may even want to lay Fibre cable along with Ethernet cables at the same time to be more futute proof.
Potential cost involved: about S$150 per port for CAT 6 Cable (which is good for 10Gbps up to 55m, this should be good enough for a typical home setup in Singapore).
https://forums.hardwarezone.com.sg/...ing-new-ethernet-port-in-hdb-bedroom.7005363/
2) For some older flats, the ONT is in a relatively central location and they may be served by just one powerful wireless router if the expectation is not too high. This is especially true with powerful wireless router like Asus RT-AX86U Pro, GT-AX6000, GT-AX11000 Pro, etc.
A ceiling mount PoE AP can also be considered to place in a central location.
You can also try to be creative and then hang a consumer wireless router in a central location even if the ONT is not in a central location.
3) Using Moca adapters are another good option if Cable infrastructure is available at home. Up to 2.5Gbps as of now. Future Moca 3.0 adapters may be up to 10Gbps.
https://forums.hardwarezone.com.sg/threads/moca-network-setup-ethernet-over-tv-cable.5675388/
G.hn2 over Coax cable may be up to 10Gbps as well.
Reference:
https://broadbandlibrary.com/a-preview-of-10g-enabling-technologies/
4) If the above two are not an option, then triband mesh solution can be a good one. Usually two pack or three pack will be good enough for the flat. Triband AX routers are still pretty expensive too, eg, Netgear Orbi RBK752/753, RBK852/853, Asus Zenwifi XT8 and Linksys Velop MX4200. Cheap option includes TP-Link Deco X68 and X75.
Dual band mesh solution may be used if the placement of the second node (and/or the 3rd node) can be accommodated.
No matter it is triband or dual band mesh solution, the mesh node needs to have good connection to the main node. The best is to have line of sight. If not, at most one wall in between.
How to choose a mesh solution?
https://forums.hardwarezone.com.sg/threads/how-to-choose-a-mesh-router.6452151/
5) Singtel FTTR is a new solution if you are willing to pay for it.
https://www.singtel.com/personal/products-services/broadband/fibre-everywhere-fttr
6) Power line adapters can be used as well if the requirement is lower (usually 100Mbps to 300 Mbps).
This is now mainly used as a low cost alternative for more proper solution.
Mesh solution using PowerLine as the backhaul is a potential solution as well.
7) Wireless Media bridge or repeater can also be used if it is applicable.
This can be used as a supplement to the other solutions.
Summary
Reference:
If you have the time and energy and know how (it's actually not that difficult if you're capable with your hands and can follow some simple colour diagrams to install keystone jacks and crimp the heads as needed), it's about a 4h job to run ethernet cabling from a central location (where the optical terminal/ONT is) to the switch. If you don't have the energy, time, or knowledge, then feel free to engage contractors to do it - but it'll cost quite a bit at $100+ per line run. You could get it cheaper if you plan ahead, or when you do it along with the electrical runs as part of the renovation job before moving in - since it'll be a full wiring quote rather than individual runs. Part of the cost comes from having to patch through the wall - I ran the cables alongside power cables for these sections to reuse the holes, and cos I didn't want to have to hack extra holes. The contractor will do this for you as part of the installation costs.
