BlackWing1977
 - Mar 1, 2006
Got half a can of Lotte Luncheon Meat cut into 2 thick slice air fried liao but in another bowl....kyoshu ramen? no meat? hotdog jiao finish riao![]()
	Why leh??why ts like my most hated enemy de
this one ish air fried again?!![]()
Freshly baked Chocolate Cake!!!
	Yes Air fried one!!!this one ish air fried again?!![]()
ish rooks notch bad wor... what bland air fryer?Yes Air fried one!!!![]()
those spring onionWhy leh??![]()
	Joyoung... bought from Taobao.. but the LCD display haywire less than a year.. but does not affect usage lor.ish rooks notch bad wor... what bland air fryer?
You dun like spring onions???those spring onion
Air Fried!!!Baked or
Chargrilled?
	Aiyoh wasted.![]()
I used this cake mix... but is all like this one.. even the butter cake will have a nice crust... maybe because it is air fryer??
Inside is very moist definitely.... because it is air fried.. the outside is crusty.. which is nice lar...Aiyoh wasted.
Betty crocker cake mix should
Come out as moist and creamy one...
Not like deep fried hum jin peng
Dun need lar... I like the crust on top... very nice... is not burnt lar...Sorry, I saw this line I was thinking about something else
Airfryer heating element too near the top of the cake so the top tend to crust or burn easy. Either use knife to cut off the crust or just cover the top with foil about 15min into "baking".
