Pocophone F3
Jun Jun
Nope, on my 11t pro. Roaming is quite smooth, without disconnect. But on my 9tpro always will disconnect then connect back.
Jun Jun
And there is a setting called "ssid handover" in debeloper settings for 11 tpro which 9t pro doesn't. I believe that is the cause of the roaming issue.
cybertech
Can get $347, but only $2 diff nia. Still worth. 11.11 best pricing was $351.
ya just got it at $347 only when the phone price for a short moment it went to $399 (-$13). It was at $412 most of the time and after all discount/voucher was at $360 in my case.
Hailgod
f3 has that setting. but i dont think it does what u think it does.
justln
Custom rom can use banking apps, Singpass, TraceTogether etc? Can someone confirm? If custom rom, which one? Need special bypass ?
Can use no issues, me using crDroid but any ROM should work fine. I never root, don't have need for any modules or root apps.
i1magic
Anybody switched to Poco F3 from Redmi Note 10 Pro?
I am kind of tempted by the SD870. But the camera is really kind of average right?
i1magic
i using redmi note 8 pro to poco f3
Oic. I was on Redmi Note 8 Pro also. I really missed the "Google Assistant" on Redmi Note 8 Pro. Can wake up the phone with just say "Ok Google". In Redmi Note 10 Pro, dunno why cannot liao.
How was the experience so far?
tingsters
Guess it might have some bugs or software issue...i got RM Note 10 not pro ver. it has some issue with the google asst... then i change back to RM note8 pro. till end of nov then i fully swap over to poco F3 which i purchased during 11 11
Poco F3 will be like more on a daily usage
Camera wise the resolution Note 8 pro will be better then Poco F3,
Lens Note 8pro is 4 (64 MP + 8 MP + 2 MP + 2 MP) but Poco F3 is 3 (48 MP + 8 MP + 5 MP)
lens note 8 pro is using the samsung while the Poco F3 is using Sony IMX582.
Screen Wise Note 8pro uses IPS vs Poco F3 while this LED.. screen color is better.
Cpu need not say liao
Memory.. Note8 pro using LDDR4 vs Poco F3 LDDR5
Memory cards.. Note 8 pro have SD card n Poco F3 None
battery Note8 pro only hav 4500 mAh and Poco F3 4520 mAh
Fast Charged.. both can use fast charge.
Wifi Note 8 Pro is Wi-Fi 5 (802.11 b/g/n/ac) Poco F3 Wi-Fi 6 (802.11 a/b/g/n/ac/ax)
Dual Sims... Both Dual Sims
Sound wise Note 8 pro is mono and Poco F3 is stereo
Headphone audio jack Note 8Pro Yes and Poco F3 No.. wireless nia.
FM Radio Note 8Pro yes.. Poco F3 NO. thru Apps.
Dolby Atmos, Note 8Pro NO. Poco F3 yes.
Weight.. Note 8Pro is heavier then Poco F3.
this is what i feel....
i1magic
Thanks for your comparison. So for Poco F3, we can just say "Ok, Google" and the phone will turn on?
The Poco F3 got IR Blaster bo?
tingsters
IR Blaster u mean the remote control?
Yes... just need to activate it can liao
link here
twosix
This is really a good phone with sd870. The stock camera app is not good. I use gcam which improves the photo quality by a mile. Just scroll back to see some photos I've taken.
i1magic
Which Gcam are you referring to? Can I use that on my Redmi Note 10 Pro?
