Ok so the Sony HT-G700 is a 3.1-channel soundbar. Can't upgrade.So
Apologies, I was referring to Sony HT-G700 instead![]()
I suggest you get a $1500+ soundbar with more features
Your swans d300 is local set? Swans come with 2 year warranty. Go get the amp changed at tech dynamicGuys,
My SwanSpeaker D300 refused to power up, having tried all possible power troubleshooting (Change plug and socket) to no avail. It is only one year old, so now I have to fork out money to buy another soundbar/speaker for my tv.
As there is some distance (at least 2.5m) between the TV and sofa, can any expert recommend any value for money soundbar/speaker to me, please? My budget is not more than $700 and below are some of the recommendations by you guys in the previous few pages of this thread.
1) sony HT G700 ($619)
2) Yamaha Ats ($499)
Any suggestion is deeply appreciated.
Thank you
Yep, for real surround effects, really boh bian, must pony up moolah for more features. I was really tired of trying out $500-$700 soundbars, and the thought of adding speakers to the rear for a minimum of good 5.1 effect didn't appeal to me.Ok so the Sony HT-G700 is a 3.1-channel soundbar. Can't upgrade.
700 i think eol liao. 900 is out leSonos beam gen 2+ 2 sonos sl or bose 700?
Which one will you get?
Hmm, if that is the case then its either arc or 900700 i think eol liao. 900 is out le
previously...i was testing out bose system...Sonos beam gen 2+ 2 sonos sl or bose 700?
Lol I just got my arc ytd, today got sub gen 3 and 2x Sonos one SL, gonna see how it sounds for my setup later.previously...i was testing out bose system...
quite surprisingly...when playing back movies or bassy music...the sub will "jump"
Am now using Sonos Beam Gen 2 + 2 x Ones + Sub Gen 3..
Weakest link is my tv coz it doesnt support dolby vision or dolby atmos haha
Might eventually upgrade to Arc though.
Wa why your coy so good one give arc. I also want leh lolDemand for arc soundbar seem quite good leh here. I’m waiting for mine to be delivered before putting on sales, got it from my coy Xmas party.
Walao Sibei Heng, but ytd they treat us dinner 200 sgd per person. Song song Gao Joo Koon eat until too full.no dnd, so give out gift during Xmas party lor, mine is 2nd prize though.
sure! Hope i can catch them when it arrives tomorrowTake some pics of how the box / TV fits in your lift bro..
If willing to pay 1K plus. Always consider Yamaha. Their tunning is quite different from other brand. My guess is hardware is mostly similar.sure! Hope i can catch them when it arrives tomorrow
Sorry to OT here, but any good soundbar to recommend in the region of $1k plus minus ?
I've been using the LG SL9YG. it's decent but disappointing in music and the wireless Sub sometimes either dont work or they connect late...a bit frustrating at times..
The only way to know if it is fake ATMOS or not is to check which decoding chip it use.I’m using a Denon
Good sound and function especially if you don’t go nuts on fake atmos
https://peteswrite.blogspot.com/2021/09/denon-s716h-heos-bar-and-dsw-1h-review.html?m=1
May I suggest you audition this before you decide on the sound qualityThe only way to know if it is fake ATMOS or not is to check which decoding chip it use.
I know Denon make very good AV receiver and frequently been rated one of the best (refer to YouTube). But not the sound bar and speakers.
Think you can check as ATMOS chip is licensed (same as DB chip).May I suggest you audition this before you decide on the sound quality
It’s definitely Not the chip that determines whether the atmos implementation or not. Please read up on what it takes to give a good atmos surround experience
The surround experience depends on the speaker placement and levels, lots of hard work with a SPL meter and some EQ software. Not a chip.Think you can check as ATMOS chip is licensed (same as DB chip).
