realtek 8821ce wireless lan 802.11ac pci-e nic
IceX
Anyone can share what is this? I saw this device shown under my network adapter settings for my desktop. I thought its a pci-e wifi card and tried connecting to my wifi networks but keep unable to connect.
meanwhile, my usb wifi adaptor has no issues connecting to my wifi networks.
loganrunning
https://www.realtek.com/en/products/communications-network-ics/item/rtl8821cesingle stream Wifi5 and Bluetooth controller
not the fastest Wifi5 option. Perhaps a driver needs to be updated?
if your usb wifi works and you are happy with it, then all is good.
lilycll
Are you using one of these Lenovo ThinkPad Laptops (E470, E570, E475, E575)?
It could be the PCI-E Wifi Card but failed to work due to incorrect or driver not installed. You may want to try to download the driver to install. See Lenovo website.
https://support.lenovo.com/sg/en/do...indows-10-64-bit-thinkpad-e470-e570-e475-e575
If not above, do advice details of your Equipment and Operating System etc.
IceX
Microsoft Windows 10 Pro
11th Gen Intel(R) Core(TM) i7-11700F @ 2.50GHz, 2496 Mhz, 8 Core(s), 16 Logical Processor(s)
Gigabyte B560M DS3H AC
Running a desktop..
IceX
I did tried installing both drivers from realtek website and the lenovo link shared in the post earlier. Still couldn't work. My TP-Link USB wifi adapter's connection keeps dropping off randomly on a daily basis. Thats why I wanted to see if this realtek is a functional wifi card.
lilycll
Running a desktop..
Go to Gigabyte Support website and download the relevant drivers:
https://download.gigabyte.com/FileL...10.123.zip?v=3c9b8f4b25ef2694ca8477c53f89c3f3
If after installed the Realtek driver still not working, you may want to check and install other motherboard drivers particularly the Chipset.
https://www.gigabyte.com/my/Motherboard/B560M-DS3H-AC-rev-1x/support#support-dl
lilycll
According to your motherboard spec has the Onboard Dual Band 802.11ac Wireless & BT 4.2 with WIFI Antenna. Most likely driver was not installed properly or incorrect driver causing it failed to be activated. Download all the latest drivers from the motherboard support site and try.
loganrunning
ah, earlier you said that the usb wifi adapter is working fine....
on driver issues, did the card ever work from day 1? if so, if it is not hardware, then the driver is corrupted or overwrittedn.
since this is a gigabyte mobo, suggest follow instructions per post by @lilycll
lilycll
Ensure the antenna is properly connected to the motherboard too. Otherwise even with proper driver installed, you may not be able to connect to your network router due to poor or no signal.
IceX
Have installed the chipset driver updates as well as the wifi drivers and wifii still doesn’t work.
gave up already. Thanks you all for the advice
lilycll
Have installed the chipset driver updates as well as the wifi and Bluetooth drivers and wifi and Bluetooth still doesn’t work.
Take screenshot and share the Device Manager screen (found under Control Panel) particularly the Network Adapter that has an exclamation mark beside. Refer sample screenshot:
IceX
sorry for getting back so late.
here it is.
