This is so stuipid
jadedRomeo
Means you're positive la, most likely in recovering mode.
Just send the positive one.
Ok what, 3 days rest.
SimpliCity2k
How the fk my first SD line so clear then 2nd SD so unclear
Both i can be sure i use the same way of digging
Dont tell me the 1st SD dig i manage to dig the virus away so 2nd SD dig like not much virus
The virus so weak de meh can dig off one ah
ya virus chua sai liao ra
rast shot ~ dig pigu dong 保证有效!
Bweebweee
If need to dig so deep to retrieve viral particles then how can Covid be so contagious?
u get what I mean?
I think doctors poke deep deep coz it’s not their hole. But in reality maybe just agar agar deep can liao
Lol at this.. agar agar apparently
optimus_prime888
If show positive then it should be positive le. Very, very low chance of false positive. My maid also same.. test both positive and negative, then a day later, turn deep positive.
georgemcics
All the same brand of kit or different?
Mine i am wtf is because is like two different brand. 1 say neg another say pos
So is 1 kit better than the other or what
Glariel
Did this back to back just now
send the below one so you no need go back to work
georgemcics
Pretty sure you had symptoms before you decided to test yourself.
The simple answer, you contracted covid-19.
Stay home to recover. Don't go out spreading the virus.
Today is my day 6 of covid
Do the test is to see if i have recovered
Just felt weird different brand come out different result
Anyway i send as positive liao
Rest 1 more day. Tml day 7 anyhow also can go out after 12pm
coyote
Yes. Everyone doing their part to contain this virulent virus... Thank you.
nyvrem
i thought MOH say after dunno day what u can go out liao even if tested positive
cyberpig
TS if feels well and dun hab any symptom, then take it as negative lah.. MOH also boh chup liao. They only interested in their vaccination KPI.. :(
