whats the best speakers for computers home theaters now?
dreamaurora
Oh. I don't fancy Denon and Marantz design. I've just bought Leak Stereo 130 as an impulse buy last weekend. It's basically a much nicer looking Quad Vena Play II that is somehow cheaper in Singapore compared to Vena. Big upgrade compared to my last Class D Sabaj. Sound so much fuller and there is a nice hint of warmness.
mac_oasis
Any small bookshelf speakers 2.0 + bluetooth for PC setup to recommend? Have used Ruark Mr1 previously
AhhHoNG
Why nobody suggested KEF LS50 META? you wan the best this is the best (Computer setup wise)
dreamaurora
Because LS50 Meta are passive speakers and he would need to get an integrated + DAC which probably would cost additional $1000 for decent one like Audiolab M-One?
If want to go passive for desktop, the best option i have heard so far is Vivid Kaya S12. Then throw in a Naim Uniti Atom. Total $13,000 SGD. The S12 is my dream desktop speaker. Probably will get Yamaha AS-2200 to pair with it and Musician Aquarius.
AhhHoNG
I mean the LS50 Meta has the wireless active vers
mac_oasis
Since you are using Ruark already, logical step up would be Kef LSX or Triangle Elara?
Is the Kef lsx worth considering? I have used pre sonus before Ruark. Was contemplating iloud micro monitors but review seems hit and misses
dreamaurora
You really have to try it yourself to see if you like its sound. Kef is well-regarded by audiophile but their sound signature is more balanced and neutral type so it's more for music listening. I auditioned Meta. It is a very good pair of speaker but I prefer the richer more mid-focused sound of brands like Triangle and Goldenear.
You can try Kef at Atlas and a few more other places like Stereo or Funan. Triangle at Alpha Audio.
Couple more options and where to audition them:
Klipsch The Fives. At TC Acoustics.
JBL Control X. At JBL Sound Gallery.
dreamaurora
Just found out that latest Cabasse 2.1 system Pearl Keshi is actually sold in Singapore. If you have the budget for KEF LS50W II but want a proper sub then consider the Cabasse. The big difference is the Pearl Sub functions as the AIO unit housing the DAC, amp, and the connectivity. Can also just buy the Sub and add your own bookshelf speakers.
https://www.cabassesg.com/pearl-keshi
Deathskull88
I have chinese DAC(Topping D90) and amplifier(SMSL DA-8S), do you think that the KEF LS50 Meta is a good fit? Am using the speakers nearfield on my desktop and mainly for music enjoyment.
dreamaurora
Should be fine. Might want a small subwoofer though like SVS Micro 3000 .
Deathskull88
Thank you for your input. Am coming from a pair of active-turned-passive Aktimate Mini speakers, so are the KEF speakers considered an upgrade?
Always wondered if subwoofer is suitable for HDB use, am concerned about affecting the neighbours lol.
wwenze
Depending on whether your active-turned-passive Aktimate still has the correct frequency response or not, the KEF is definitely an upgrade.
dreamaurora
I put my subwoofer on a rack, helps to reduce the vibration. So far quite ok, even at 1 or 2 AM I turn on music nobody complained.
Yes, KEF should be an upgrade. But if you are willing to upgrade you should consider other options at this price range that might be more suitable for your room or musical taste: Amphion Argon 1, Triangle Comete 40th, GoldenEar BRX, Cabasse Io3, and Sonus Faber Sonetto 1.
One thing to consider is whether you have space from the wall. The LS50 Meta and the Argon 1 for example are rear ported so need around 20-30 cm from the wall. Those with side or front ports you can safely put all the way back against the wall.
petetherock
Moderator
Moderator
Yes, KEF should be an upgrade. But if you are willing to upgrade you should consider other options at this price range that might be more suitable for your room or musical taste: Amphion Argon 1, Triangle Comete 40th, GoldenEar BRX, and Sonus Faber Sonetto 1.
What kind of rack do you use ?
Most racks I know aren't meant for subwoofers and make the sound worse..
