Realme GT2 Pro Series
dreamcast18
Ibywind is coming out with tempered glass for the phone too.... Can wait for this. Used this on p6 and poco f3. Value for money and damn smooth coating... 8.99 for 2 piece and come with alignment kit
link?
dreamcast18
Help! I can't seem to power off or reboot the phone even when i hold down the power button.
Edit - nvm...what a pain..must hold volume up and power button
ranmaru1987
yes.. ibywind is the best.. used for my p6 and s22+ now..
KeYoKe
Havent launch. But its inside their plan. Asked them at shopee
Ya. Want copy fruit phone don't know for what
S22+ can work with fingerprint? Nice. Cheap somemore and the coating solid
ranmaru1987
can working perfectly don't even need to re register.. the coating damn solid.. one of the best..
Nakedtoes
Okay i saw 1hz finally.
For 1hz to work, u need quite high brightness like 80 percent brightness. At 50 percent brightness is 5hz lowest, at 20 percent brightness is 10hz
Interesting.... Guess they dun want to introduce flickers.... Anyway I see ibywind Glass is same like smart devil in taobao. The coating is the best... But I wunt said glass is the best... So far best tempered glass I use came from monqiqi brand.
KeYoKe
Yup. U are right about flickers. My poco f3 has flickers on custom roms with adaptive refresh rate
Yup ibywind is good with installation tray and yup i tried monqiqi before. Its good too
ranmaru1987
monqiqi good also.. monqiqi v thick.. ibywind and smartdevil thinner..
Nakedtoes
The problem with ibywind and smart devil is the glass is not full coverage.. Sides of the glass near to oled screen got the rainbow effect. And the glass after a while will have bubbles forming... Monqiqi is full coverage with black edges..good thing is full coverage. Last very long.. Bad thing is the black borders left and right is 0.5mm smaller then actual screen. . Top and bottom no issue duo
ranmaru1987
I know what u talking about for the rainbow effect.. but so far my ibywind for s22+ no such problem.. cos it extends out to the bezel by almost 1mm for the sides and top and bottom around 1.5mm..
ya lo.. I dun like that the black border will cover the screen.. iirc smart devil got black border also.. but nv cover as much as monqiqi.. I think .25mm only..
s1mple
The screen is flat which I like it a lot, there should not be rainbow effect if u apply it properly. Worst case u could put little bit uv glue if there is gap near the edge.
Existing screen protector is also good, I don't see there is need to replace for now.
So far so good for me, no issue with Volte on MyRepublic network.
Nakedtoes
The flat 4k screen is the attractive point.. I dun like curved screen and never use one.
dreamcast18
concur..i hope the current screen protector last for a while.
my daily driver phones, main is OP10 Pro and secondary is GT2 Pro
Bro, how come 2 phones ? You got small 3 or big Business?
bennyp_18
Is the battery life up to your expectations? What apps do you all use to monitor the battery life?
KeYoKe
Under battery menu can monitor battery life liao
I'm still monitoring. Seems like 120hz can yield 8hr sot. 60hz should be around 10 to 11 hours. Currently still testing 60hz
