- Jan 7, 2007
It’s better to rely on mewatch if you have poor reception.
just use StarHub and it’s set top box.
yes, you can use existing uhf antenna.Hi
Need some advise.
for landed property do I need fix a separate Digital Tv tuner on rooftop to improve signal ?
I read mediaxorp site can use existing UHF antenna for Digital tv ?
Oh existing UHF antenna can receive digital tv signals ?yes, you can use existing uhf antenna.
you can also buy a dedicated outdoor antenna for DTV.
Hi
Need some advise.
if you want to watch SCTV, internet IPTV is a better option.Just to check if SCTV still has analog broadcast ?
easier to receive than DTV, quality much better than analog broadcast.
at least 720p
if you have android box, the SCTV channel can be shown on many free IPTV apps.Thanks ! Can watch on their webby.
Got make sure your usb thumb drive got enough space to record that long in the first place?I try to record a movie shown on channel 8 last Saturday using USB thumb drive on my NSM setup box with the timer function with a start time 2220 and I indicate 2h 50 minutes, it stopped the recording at 2335 why is this so? Could anyone advise how I can record a show for more hours which can span more than 2 and half hrs to 3 hours or more thanks
Oh yes there is ample space in the usb driveGot make sure your usb thumb drive got enough space to record that long in the first place?
Try Challenger, best denki, courts, harvey normanHi. Any store or place to buy a set-up box.... prefer to get one immediately rather than online to replace the one that has gone bonkers at home .....
TIA ....
I don't use NSM box but maybe you can try state a stop time as well if there's such option.Oh yes there is ample space in the usb drive
Thanks for your reply. However it only allow you to state the number of hours to record from the start time and date of record.I don't use NSM box but maybe you can try state a stop time as well if there's such option.
