- Sep 16, 2018
Hi, I plan to switch to Singtel 1 gbps basic plan due to staff benefits.
Currently, my setup is as follows:
ONT -> wired lan ->Router 1
Router 1 < 5Ghz Wifi > Router 2
Router 2 -> wired lan -> PC
(1) If I switch to Singtel which will give me ONR, can I connect a LAN cable from ONR to Router 1 via wired lan as above?
I'm not a technical guy but I remember I just had to configure Router 2 to have this setup. Since many are saying you can't configure much on the ONR, which would be acting the equivalent of ONT+Router 1, I guess it shouldn't affect me too much...?
(2) If not, can I connect ONR directly to Router 2?
i.e. ONR < 5Ghz Wifi > Router 2 -> wired lan -> PC
(3) what are the usual charges that I must be aware of to check if they will be waived since I'm switching from 1 ISP to another?
Eg. Registration fee, Service Activation fee, anything else?
(4) Can I port my digital home number from M1 to Singtel?
Personally, from what i read here, Singtel= ONR + high international latency=bad but the staff benefits are kind of great to ignore
If you really want to go with Singtel because of the Staff benefits, that is fine as well.
What are your existing Router 1 and Router 2?
1) Yes you can, it is better that you set up Router 1 as AP to avoid Double NAT.
Ref: https://kb.netgear.com/30186/What-is-double-NAT-and-why-is-it-bad
2) ONR does not have wireless function. Singtel will give the Singtel Mesh Router (AC1900) or Singtel Mesh Extender (AC2600). Both are not too bad but not too good either.
3) You'd better contact Singtel to confirm. Usually you will need to pay for NLT charges.
4) That should be okay.
What you need to worry about is whether you need something that ONR can not do.
For example, you can not change the DNS server.
And you need to check whether you need certain port forwarding issues if you need that.
Ref: https://forums.hardwarezone.com.sg/threads/singtel-port-forwarding-issue.6755972/
